Duraspark 2
Discussion in 'Technical' started by Halebopp, May 9, 2005.
  1. Halebopp
    Halebopp Member
    Ankeny Iowa
    First of all I am planning to keep my 250 and build it up, a little at a time, on a shoe string budget, to that end.... I talked to Mike with Ford 6 .com last Friday, and he said the first upgrade he would advise would be to switch out the existing distributor, and upgrade to the Duraspark 2, with either a ford or gm module or an aftermarket one, with limited.. basically no experience he says it is a very straightforward upgrade... comments? Suggestions.
    He said to just buy the set up for a 78 fairmont.
  2. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Might also want to look at the Pertronics set-ups. They replace of the guts of the original dist. are very easy to install, give you electronic ignition plus no box to mount on the inner fender. I think they are selling for around $75 or so at Summit
    clint
  3. Halebopp
    Halebopp Member
    Ankeny Iowa
    cdeal, is that under a listing for Mustang, or is it listed for Mavericks/Comets.. Fairmont?
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  5. Halebopp
    Halebopp Member
    Ankeny Iowa
    DM which one did you do the duraspark, how much of that kind of work had you done before that, will it work with the stock carb set up.. for now. I plan on going with a 3 carb set up eventually
  6. dmhines
    Cumming, GA
    100% Stock 74 250 Engine with a C4. Duraspark setup from a 77 Mav. Adjusted my plugs from .036 to .050 as per Chiltons. Runs great and idles much better.
    None of this was necessary but I also removed all the EGR crap and have basically 2 or 3 vacuum hoses left. I used a non-EGR carb plate from a 1970 250. I also swapped to a 77 carb since it was recently rebuilt and my 74 was original.
    I have a freshly rebuilt 250 and a 3-speed manual tranny that are going in the car. I just wanted to do the electronic conversion now so I have one less thing to troubleshoot later ... :)
  7. Mavaholic
    I"ve put Dura Spark set ups in alot of my cars. I've also used Pertronix. The Pertronoix is way easier to install, but the Dura Spark is pretty easy too.
  8. Mercurycruizers
    Venetia, PA
    Ditto on the Pertronix...very easy to install. I have it on a 200 cu in & 302 cu in....
  9. Halebopp
    Halebopp Member
    Ankeny Iowa
    Where do I find a pertronics for a 250 ? what year Ford and car do I look under, checked the above website under maverick, only came up with plug wires.
  10. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
  11. Halebopp
    Halebopp Member
    Ankeny Iowa
    Thanks MP , appreciate it! (y)
  12. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I'm getting a 200 i6 this weekend and I want to get the pertronix for it, I flipped through the catalog but I didn't see a kit of sorts, what is it under exactly?
  13. xpsnake
    xpsnake Bruce
    Is it the Ignitor setup? If so, what year model # should I look at for my '71 200ci?
  14. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    pertronixs ignitor
    I have pertronix igniter in my 72, I had it in my 73. Fits in your distributor, no boxes or bunches of wires to clutter up your fire wall, no more points, and just 2 wires red to hot side of coil , black to other side. You will need a hot coil. I think its a great thing...Jim
    $69.99 plus tax.(y)
  15. Halebopp
    Halebopp Member
    Ankeny Iowa
    My questions are the same as XP, do I need to buy , dist , module, ign box? what I shoud I buy, I am totally cluesless on what all I need, couldn't find the Dist for 6 cyl, only saw the one for v-8 fords 221-and bigger. Sorry if I am being thick headed, but not sure
    how to finf what I need, to make this upgrade, not even sure all of what I need, there is a module, dist , ignition box.... :huh: :hmmm: :90: Is the flame thrower the one I shoud be looking under??
