Duraspark coil output
Discussion in 'Technical' started by jasonwthompson, Apr 2, 2014.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I have a stock 75 maverick with a 302 and factory Duraspark ignition system. Does anyone know what the factory coil voltage output potential is? I am having ignition problems and have already replaced the box with a new green harness unit. If I have to replace the coil I was thinking about something that would work without having to add a ballast resistor, but still had more umph than the factory unit.
  2. Blue Brick
    Blue Brick Member
    Up to 42,000 Volts.
  3. rthomas771
    I was running a TFI coil and bracket that came off a '93 Crown Vic with my Duraspark II. The TFI coil gets a full 12 volts whereas the typical DSII coil get about 6-8 volts. Some people claim it's 1-1/2 times hotter than the conventional coil.
  4. doncomfort
    chillicothe oh
    Glad I saw this. I have a full 12 volts running to my coil. So hooking up a DS coil to that would cause damage to coil?
  5. Krazy Comet
    The resistor should be in the wiring harness, feeds the R/G wire that powers coil so there won't be any voltage drop until engine is running... The coil only draws current when being driven by the module and it(module) must receive a pulse from the distributor...
    Any damage would more likely be to ign module than coil...
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    I NEVER run the box because it just interferes with the whole package when using a hi-po coil. None of the other guys I see running DS disty's use them either.
    IIRC.. the last one I used ran around 9 volts to the disty(or you'll fry the pickup) and full 12 V to the coil. It's been a while though and I could easily be wrong about the votages.
    PS. regardless of the numbers thrown around for the factory coils.. I've ALWAYS seen better spark energy from even a cheap aftermarket hi-po coil. And I know for fact that the stock stuff won't keep making good power at higher rpm like the hotter aftermarket stuff will.
  7. jasonwthompson
    Carrollton TX
    Thanks guys. I was thinking the same thing about the factory one being inferior to even a cheap after market one.
