% 10 Finally got the hang of the sim dyno...close enough my engine 75 302 performer cam performer intake holley 4BBL 600CFM 65 289 heads comp ratio10.0 W/manifolds i'll be happy to run you numbers if you wnat
What info you need? I have a 95 5.0 Roller ... 100% stock. Edelbrock Performer RPM intake and Edelbrock 1406 Carb. I would like to see the current numbers with the Hooker 6901 installed ... and what they will look like when I put the factory manifolds back on. Thanks ...
Dan, Have you ever thought of having your stock manifolds "Extrude Honed"? It is a process that enlarges and smooths out the manifolds inner ports from end to end making them flow much better than stock, I assume you were asking the above question because you would prefer the appearance of manifolds on your car.
i got dynosim crapola also , but i dont know how exact it is , or how good i am with it , try this i got 390hp out of my dynosim with this set up 351w stock bore/stroke 69 (c9) heads, FULL port/bowl, gasket matched to Edelbrock RPM air gap , with a full port holley 750 9.7-1 (ish) 1 3/4 prim. 3" collector open exhaust comp cams 292h 518/518 244@ .050 try that on for size:evilsmile
OK,DO ME!! 1991 5.0 ho,performer rpm intake,b 303 ford racing cam,1 5/8 headmans, ported e7 heads,650 double pump holley. Thanks Derek.
how bout 302 bored .030 over comp cams xe274h .520/.523 230/236 at .050 performer rpm edelbrock 1405 carb performer rpm heads 2.02 valves 9.5:1 compression hooker 6901 open exhaust
my buddy will be in hot rod U in a few weeks, access to a chassis dyno, we'll hopefully be doing a dyno tune relatively cheap
347 10:1 Canfield 195 aluminum heads (2.02 & 1.600) Victor Jr. 750 DP Solid Roller .624 lift, I- 236 @ .050, E- 250 @ .050, 112 lobe separation 1-5/8 long tube headers Thanks
Wow ... quite a difference between headers and manifolds ... how accurate are these numbers in real life? Most articles I have read on the internet show a 5-15 HP gain from headers ...
