Dyno Tune Results
Discussion in 'Drag Racing' started by Rick Book, Oct 14, 2006.
  1. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Whew! It's been a long day.
    Reader's Digest version: 1st run=313RWHP. Last run = 350RWHP.
    Got at Strictly Performance at 9:00 - unloaded the car, chatted with Scooper and Anna a bit, then put the car on the dyno.
    The first run was without a chip (Diablo Chipmaster). Results: 313RWH. The "Torque" part of the data acquisition wasn't functioning. Figuring more hp = more torque, it wasn't that big of a deal. I just wanted to optimize what I had and a HP reading would do it.
    After adjusting timing, fuel pressure, replacing the old chip (apparently I fried it at some point) and tuning the new one AND taking the 6000 rpm limit pill outta the MSD, the A/F mixture was clean all the way through the rpm range. The last two pulls were within 3 hp (347 & 350) - so there was no need to go anymore.
    I'm pleased with the results. Afterall, the engine was built to be a streetable engine (relatively small cam and low compresion). The car starts and idles fine and no back-firing, spitting and sputtering that was going on before during WOT.
    I also learned I need to move my shift light up to about 6K.
    Next stop? Nitrous. :dance:
    (I 'might' be going to the track tonight - will update later)
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    congrats rick. sounds like a fun night at the track
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sounds like a great day!
  4. scooper77515
    :ttiwwp:
    I didn't take a lot, but hey, it is just a car sitting still, making a CRAPLOAD of noise, in a small tin building :D
    I just LOVED the look on Ricks face (probably the same look was on mine) when the guy revved it up to 6200rpm. I have never heard a Mav go that high, and I don't think Rick ever heard his go that high. Anna jumped back expecting rods and chunks of oilpan to come at her :clap:
  5. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    6200? hmmm i know if it was my car, there would be a bit of a pucker at 6000+ ;)
    sounds like fun:cool:
  6. stmanser
    Davenport, Iowa
    awesome
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I have revved mine to almost 7k just to see if it would blow up. :evilsmile need a reason to build a 331 or 393w. A couple broken valve springs but nothing let loose yet.
    Rick Great numbers. What's your combo?If I remember it was 302 based stroker. I'm waiting on the track time results. Hurry up already:D
  8. eddie1975
    Martinsburg, WV
    sold
    can i borrow your car??? ill fix you up:evilsmile
  9. RabidCustoms
    I'd bet your face looked about like mine when ours hit 8 once:yikes: ...:D
    I kept it down to under 7 most times after that, but they sure sound nice up high (y)
  10. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Good deal on your Dyno tune Rick ! I want to see some footage when she makes a "good" Run at the track (y) I shift mine at 6,300 at the track... It hit the revlimiter once which was at 6,800
    when I was "playin around" doing a burnout.:p
  11. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Great numbers Rick!(y)
  12. Maverick Man
    California
    wheres the video?!!!!
    btw what compression is it?
  13. blugene
    What does something like that cost? Do they do the adjusting where needed?
  14. Rick Book
    Rick Book Member
    Thailand
    Yes, my eyes did get big as saucers when I heard the ol' Maverick rev to 6200 r's. :eek: He took it to 6400 on about the third run. More :eek: from me. Yes, I was thrilled that no pistons went flying through the roof.
    The combo is a 347 stock block. AFR185 heads. I'm not sure what the compression is. The cam in a small street cam. Holley Systemax II intake. 32Lb injectors. 75MM MAF and ? TB. MSD 6AL. Aeromotive 1000 Fuel Pump. 6908(?) Hooker SuperComp 1-3/4" Long Tube headers in to 3" Dynomax then dumped out (jaheez that thing is loud!)
    I couldn't wait. I took it to the track tonight. See my other post.
    PS. Thanks for taking the pictures, Scott. I think I might've taken a couple. Sorry guys, no video. :(
    edit for bluegene: I had to buy a new chip. The one I had was fried. It was only hitting on 7 cylinders. Five dyno pulls. Hooked up the transbrake and line lock switches and wired the 2-step with a 3k pill = total $675.
  15. riporter
    riporter Member
    Charleston S.C.
    :dance: Good stuff Rick...it's good to know the numbers...sure helps to know how to set the car up for the track...I'd sure like to get mine on a dyno at least once...my shift point is 7200...at 7600 it doesn't have anymore to give...I have taken it to 9000 on a burnout...the first time we took it to the track after putting the pop-tops in it. The builder comes running back to the pits after the pass cussin a blue streak...he forgot to put the limiter back in it:rofl:
