e-brake relocation
Discussion in 'Technical' started by Cenzo777, Aug 10, 2008.
  1. Cenzo777
    Cenzo777 New Member
    Connecticut
    1970 Ford Maverick 2 dr
    has anyone relocated the e-brake from a floor pedal to a handle on the trans tunnel and / or console? any advice appreciated.
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Central location would be sweet.
  3. Dave B
    Did you see the writeup in Modified Mustangs & Fords (sept 2008) issue? it's about using the Lokar kit, looks pretty neat.
  4. 72MAVGRABHER
    Roanoke, Va.
    yeah i saw that as well... if I had the several hundred for that kit, i'd be all over it...
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Why not take the entire handle and cable kit from a Mustang 2?
    I have never tried it, but it is the same size car with the same 8" rear.
    It all should be able to retrofit over to a Mav.
  6. Dave B
    It's only around 250 for the handle and the cable kit at Summit, not too bad. I think it would be less work than trying to retro fit something. I try to find the easiest way, I fix things all day, and all night it seems.
