edelbrock 500 cmf
Discussion in 'New Members Forum' started by busyb187, Nov 22, 2010.
  1. busyb187
    busyb187 Member
    california
    1971 ford maverick v8
    hey im thinking of replacing the carter afb carb that i have on my 302 v8 maverick. i dont know the exact size because when i bought the car it already had the carb. its been giving me lots of problems and i was told by a mechanic that i should get a 500cmf for my car. is he right? any suggestions? i just want my car to run smoothly and not have any fuel leakeage issues. is a small carb better or a bigger carb better? HELP!!!
  2. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    Years ago,I ran an edelbrock 1406 (600 cfm,electric choke) and never had any issues with it.Engine ran fine,with no overloading.The edelbrock and carter,are basically the same carb,so your setup would remain the same.If you wanted to go with the manual choke,it's p/n 1405.:tiphat:
  3. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Carter AFB and Edelbrock Performer are exactly the same carb, you can even use the same rebuild kits.
    I love them both. They are easy to tune and easy to build. Before you replace it, try a rebuild kit. Also find out the CFM of the carb you have now. If you need some help with that, post the model number and we'll figure it out.
  4. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  5. mojo
    Welcome from Northeastern Illinois...:Welcome:
  6. busyb187
    busyb187 Member
    california
    model num
    cant find model number. where can i find it?
  7. Boosha
    Buckeye State
    On the edel. the #'s are on the left mounting ear,if you are standing in front of the car,looking at the carb.Carter might be the same
  8. busyb187
    busyb187 Member
    california
    numbers
    only numbers i can see on the carb is by where the accelerator is connected to the carb. it has an 8540 mark on it
  9. Boosha
    Buckeye State
  10. coutangman
    coutangman Member
    Charlotte, NC
    Welcome to the Madness of Old Cars! 1406's are great carbs. They are 600 cfm's. I have 5 of them on my vehicles with little to no problems.
    Jim
  11. motormouth
    motormouth New Member
    Montreal,Quebec -Canada
    No longer have/drive one
    500cfm replacement
    The Holley #4412 S is the best 500cfm on the market for a 302c.i. 2-barrel street replacement application.When you make the swap, also include a K&N replacement air filter for the Best results. Hope this will help you.
    Cheers,
    Motormouth.
