edelbrock 7121
Discussion in 'Technical' started by comet 75, Jun 8, 2005.
  1. comet 75
    comet 75 comet 75 swap 302
    Quebec
    mercury comet 1975 302
    I installed my EDL-7121 performer RPM last week and see that some parts doesn't fit like water outlet for the heater the one on my old intake is to small for the hole in the new intake (see picture 1)
    what's about the other hole some kind of cacuum do I need to install the old parts that screwed ther or I just need to put plug on this hole (see pic 2 and 3)
    I bought too this carb. Motorcraft 4160 holley 600 #E4ZEYA A4H3 with conversion kit #34-6. what is about this conversion kit I read it's to be able to change the jet but don't realy understand all about it so does some body can give some more info about the carb. I bought?
    thanks
    David
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    David,
    You can buy adaptors for brass and steel water fittings. Try your local parts store. The
    'HELP' section usually carries a variety of inlets/outlets or should be able to get you an
    adapter to make it fit. Be careful with the threads, get the correct size.
    The outlet at the front is for the heater hose inlet, the one at the back is in fact for
    vacuum.
    Adapter for the carb I am not sure about. It could be for adapting the carb to a particular intake.
    Good luck.
    Seth
  3. comet 75
    Quebec
    sorry forgot to say that the conversion kit is to convert a 4160 to 4150 ???
  4. stmanser
    Davenport, Iowa
    i dont see any pics.....just your web site link.....am i missing something?
  5. bmcdaniel
    A 4160 has vacuum secondaries and a non-tunable secondary metering plate. A 4150 is usually a double pumper and has a secondary metering block with replaceable jets and power valve.
  6. comet 75
    Quebec
    Stmancer: no your not missing something I'm not aable to upload the pic. I'll try again may be or tomorow
  7. comet 75
    Quebec
    get it yes
    here the pic now the question is what should I do with 2 and 3 hole since I remove egr and other emission control ????
    I read the instalation sheet of the intake and they talk about dowel pin to remove Where is this dowel pins I speak french so dowel doesn't mean anything for me do I miss something???
  8. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Holes 2 and 3 look like manifold vacuum ports to me. You can buy threaded pipe plugs to close off the holes in the intake you aren't using. About 8 bucks for a set of 5 from Summit in chrome, blue anodized, red anodized, or plain aluminum (i found these on their site doing a search, they are not listed in their catalog). The only things the parts store had I checked were ugly brass things, but your luck may vary.
  9. Scotty P
    Scotty P Member
    santa rosa, ca
    1= Heater
    2= Temp sending unit
    3 = Vacuum Port
  10. comet 75
    Quebec
    thanks matt, but do I need these vacuum port, what is the need of these??? Do I need it??
    Thanks Scott, but I'm not sure about temp sending unit if my memory's good my temp gauge was plug at the front on driverside of the intake (see pic #4)??
  11. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    #2 is not a water port. It is a vacuum port.
    #4 is for a temp sending unit.
    Plug #3 unless you need a second vacuum port.
    #1 is again to the heater core.
    Seth
  12. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    correct(y)
  13. Grabber5.0
    Kansas City, MO
    71 Grabber
    That means I was right too mister :p
  14. Grabber5.0
    Kansas City, MO
    71 Grabber
    You can draw manifold vac off the back of the carb, or off the intake. I think I used the one on the back of the carb for the power brakes, and the one off the intake to run to the vac modulator on the tranny and the vac can for the climate controls. I ran the PVC to the front port on the carb. I just realized I have way to many vacuum lines. :16suspect :D
  15. comet 75
    Quebec
    I put on my car a c4 trans. from granada 1977 does it possible that I don't have any vac modulator???
