Edelbrock cleaning
Discussion in 'General Maverick/Comet' started by randytatum, May 3, 2013.
  1. randytatum
    randytatum Member
    mccomb, ms
    I need a good easy way to clean my intake im going to put on in a couple weeks, its always been a tough job cleaning these intakes for me. Like always I need some info as u can see its nasty:(
  2. driftwood
    driftwood Member
    aberdeen,oh
    95mustang gt convertable 74 maverick, 75 four door,71 parts car, 67 couger 71 jav. sst
    i'll tell ya what i did with mine. sand blasted it with a really fine sand then blew it of really well and it looked fantastic as good as new or better then took a high temp clear coat and put a few coats on and wow it looks good and cleans up ten times easier now when i spray it off. hopefully don't need to tell ya to tape up the carb plate and plug the holes.:biglaugh:(did my aluminum valve covers that way to)
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. that or glass beading for an even shinier look. either way they need to be cleaned very well afterwards.
  4. 71gold
  5. lm14
    lm14 Member
    Iowa
    If it's just dirt and gas stains, try a caustic mag wheel cleaner. Not the "good for the environment" stuff, you want the nasty stuff that stinks and works.
    If that fails, then you can glass bead. When you think you have all the beads cleaned out of it, start over and clean in again.
    JMO,
    SPark
  6. randytatum
    randytatum Member
    mccomb, ms
    yea i got some of that, i think i might give it a try... i been sooooooo lazy this weekend.
  7. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    Machine shops usually clean them cheaper than I care to scrub one. About 10 bucks around here.
  8. John Holden
    John Holden Member
    NJ
    The finer the glad beads or sand, the duller it will turn out. Use a coarser media if you don't want it to end up very dull. Use less pressure. Then if you want to shine it up after blasting take a little tooth brush size wire brush to it.
