efi gas tank question
Discussion in 'Technical' started by jnew42, Jun 27, 2011.
  1. jnew42
    jnew42 Member
    Sacramento, CA
    65 Comet caliente 4 door
    I have a 65 comet that I'm converting to a 5.0 efi, is is there an efi gas tank out there that is a close fit? I can weld a little so as long as it's close I think I can make brackets or whatever I need, I just need one that's close. I'll be going to pick and pull soon so I'd appreciate some ideas of where to start looking. Thanks guy!
  2. 71gold
    this is what did to my stock Maverick tank...
    http://mmb.maverick.to/showthread.php?t=75382
    ...:Handshake...
  3. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Around 1993 Dodge caravan has a rectangular tank that is very adaptable, has feed and return lines might be just what you need, only thing that might be a concern for you is fill tube goes in the bottom of the tank on the left side.
  4. rthomas771
    Run the return to the tank's drain plug
