EFI Gas Tank
Discussion in 'Technical' started by Mustangnut, Nov 13, 2014.
  1. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Just curious what the best fit / value might be for an efi gas tank.
    I have a fuel cell in the car right now and figured it might be cheaper and easier to just get an efi gas tank with an in tank pump. I also wouldn't be upset about being able to hold more then 8 gallons at one time either lol.
    I found a few used mustang tanks complete and a few new ones bare. They seem to be a tad bit big so wondering what you guys might have used in the past.
    Thanks
  2. 71gold
  3. Krazy Comet
    On a stock system the F/P regulator on fuel rail sets pressure, as long as it's operating makes no difference what the pump will produce... Well that's assuming it can produce more than 39 psi under load, which is where the stock system operates... At idle or part throttle cruse(high vac supplied to regulator), it will be around 30-33 psi... If a stock system is operating at more than 10% above the specs it's going to be too rich...
    BTW in good cond the Stang/LSC/Turbo Coupe pump will produce over 100psi if dead ended... Problem comes when they've aged and not able to produce enough pressure for the Turbo Coupes(54psi under boost, delivered by 35Lb injectors), so it falls on it's face... Pump in same condition on a stockish HO 5.0 with 19Lb inj isn't degraded enough to make a noticeable difference...
  4. tody
    tody Member
    cologne, germany
    i have thought of starting with a new maverick tank for the later models and using an aeromotive phantom 340 pump.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    If you already have a fuel cell just get an inline walbro 255lph pump. They're cheap and reliable, and it'll give you plenty of room for performance upgrades later.
  6. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    How much are the walboro 255 pumps?
    Edit * Found them on amazon for around 100 bucks.
    I might just have to do that in place of doing a tank swap etc.
    Thanks
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I would pay the extra $20 (or whatever it is) to get it from summit. There are knock off versions of this pump, so beware.
  8. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    The problem is that summit is 30 bucks more expensive and doesn't include any of the hardware. The amazon sellers include the hardware for 108 vs the 130 from summit.
    I'm going to look up the seller on amazon and see if its legit. So far I've had nothing but good experiences with Amazon.
  9. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    If you'll be doing this may as well get a SS mustang tank then proceed with the phantom kit.
    And to control pump either aeromotive voltage controller or a flow worx module
    also aeromotive is releasing both a twin 340 pump lot along with a single e85/flex pump..think ot was 450 lph?
    Actually
    http://blog.motovicity.com/?p=4702
  11. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Problem is, Amazon usually finds out after the fact. I'd pay the extra to get a legit pump from a vendor who'll back it up. Do a search on Chicom knock-off pumps, there's a ton of info on failures out there along with some "how to tell the difference" info...
