Elctrical Problems
Discussion in 'Technical' started by BenjaminJR, Jan 8, 2020.
  1. BenjaminJR
    BenjaminJR Member
    Yucca Valley, CA
    1972 Ford Maverick Grabber
    So I have an issue with my headlights and my left tail light. The headlights are not working and the left tail light is a lot dimmer than my right one. What could cause this?
  2. bmcdaniel
    Poor grounds.
    71gold likes this.
  3. Krazy Comet
    Yes especially on the tail light being dim...
    Could be same on headlight but I believe there is a seperate ground for R&L, rarely both are failed at same time. I'd check for voltage at lamp sockets, if dead back up to dimmer switch... Still none, check headlight switch. If there is voltage at dimmer, problem is probably bulkhead connector.
    If high beam indicator works, problem is probably bulkhead connector.
    RMiller likes this.
