Elect water pumps worth it?
Discussion in 'Drag Racing' started by pedal2themetal, Mar 28, 2012.
  1. pedal2themetal
    pedal2themetal Member
    Boise, Idaho
    1961 Comet daily driver, 1964 international 4 door truck w/460, 1974 Mavrick going to be 302 bracket car, 1979 AMC Concord wifes car, 1989 Ranger, 1974 pinto sleeping trailer project, 1976 Olds Cutlass son's.
    anyone have an opinion on elect drive set up for mech pump or just get an elect pump? It's going to be for my Mavrick 302 drag project. Wanting to squize as much out as I can cheaply. So it well be all drag no street time , Unless I can get the title transferd.
    Don't want to run an alternator either, maybe two batterys?. thanks
    tim
    you cant total a race car
    you just get tired of fixing it.
  2. injectedmav
    injectedmav Member
    Georgia
  3. pedal2themetal
    Boise, Idaho
    Thanks for the link :)
  4. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    I run an electric pump and fan. It lets you cool the motor between rounds. I also run 2 batterys but I run an Alt. Charging batterys between rounds is a pain to me. You loose very little ET running an Alt.
  5. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Amen! Keep the alternator! Power loss is negligible, and if you're running a modern electronic ignition, it needs a full 12 volts to operate optimally.
    Pulling the alternator belt is 60's & 70's thinking :)
  6. Joe Dirt
    Just run a water pump drive cheapest solution for the same goal
  7. yellow75
    Tillamook Oregon
    Xs2 and you could even have a spare motor for less money than an electric pump
  8. don graham
    Moroso makes the water pump drive. I used to carry a spare in the trailer. I use an electric Mezeire pump and am really happy with it. Problem is if something goes wrong you can't just run to the parts store for another. Even the gaskets are specific for that pump. I also run an electric fan and 2 batteries and use an alternator.:)
  9. pedal2themetal
    Boise, Idaho
    Thanks everyone for there input..I leaning towards the drive system.. and I guess I'll keep the alt.:thumbs2:
    tim
  10. mavman
    mavman Member
    Arkansas
    Keeping the alternator is good, but it's not necessary, especially if you have very few electrical devices. Some guys want to power EVERYTHING from 12v. Datalogger, crossover/delay, electric fuel pumps (some cars have 2 or 3 of them), nitrous solenoids, etc. If you're planning on the KISS principle (keep it simple, stupid), no alternator is fine. Just charge it between rounds. Doesn't take long to recharge if the battery is any good. The alternator doesn't pull much power. Water pump does but the electric drive is worth some HP. And it lets you cool between rounds. Electric water pump does the same thing, just more expensive. But it looks nicer and pumps a LOT of water. And it's a little bit lighter than all of the "kit" parts of the WP drive kit.
    That said, the going trend these days is to put a 16v battery in there and enjoy faster cranking, more water pump output, better lights, etc. Downsides: not everyone carrys and extra 16v charger with them, so if yours fails, you're more than likely SOL. Same goes for the battery. Costs more (battery + charger are $400-$500) but worth it if you ask me, especially if the engine has any balls. All of the 12v accessories work fine on 16v. At least mine do.
  11. injectedmav
    injectedmav Member
    Georgia
    Ignition systems like 14 + volts also. If you don't want an alternator, the above mentioned 16v systems would be the way to go(with the stated downsides too)
  12. Boss302maverick
    Boss302maverick Member
    New Jersey
    1971 maverick grabber
    I am no expert, but have been drag racing competitively since 1985 (some time off here and there) I used to run 1 battery and no alternator, 2 batteries and no alternator, regular batteries, deep cycles etc etc etc. For the last 10 years or so I have gone to 1 925cca battery in the trunk and one of the one wire mini alternators (hitachi) and its the best combo Ive had. I have always ran a water pump drive, and when you start going rouinds, and you haved to go right back to the lanes for the last 2 or 3 rounds, you start having problems trying to keep the car cool and keep the batteries up. and if you run an MSD, its a must, you need the the voltage.
    Duane
