electric fan CFM
Discussion in 'Technical' started by 71gold, May 13, 2007.
  1. 71gold
    anyone have a link on "how to pick an electric fan"?
    i was wondering if you could get an electric fan with too many CFM?
    i am looking at upgrading my fan and i saw one with 4,000 CFM.:yup:
    you could suck a cat through the radiator with this...:D
    i am running A/C and trans. cooler.
    ...:bouncy:...
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Yes. You can have too many CFM&M's.
    Too many CFM's will pull your car down the road and will cause your brakes to wear out prematurely. :yup:
    Note: Post video of sucking a cat through the radiator please. :D
    ('Sorry. I imagine there is a "diminishing results" affect at some point :huh: -
    A good by-product of the Super CFM 4000 Type R is that the noise alone is enough to scare all the cats away from your radiator.)
  3. Earl Branham
    Lugoff, SC
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Would this be the fan that goes to the infamous picture of a radiator???
    Would you please post a picture of this also????
    And yes I would want to hear (from a far distance of this fan) and if no sound barrier broken, I would go for it!
  5. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
  6. 71gold
    REV UP, & COOL DOWN! Zirgo's 16 inch flat blade automotive cooling fans represents the ultimate in cooling technology. With a length of 16 inches, a height of 16.7 inches, and a depth of only 4 inches, the Zirgo 16 inch flat blade cooling fan packs maximum performance into a minimum of space. Zirgo high torque fan motors feature sealed ball bearings and fully balanced blades which insure low noise levels and a long life of smooth operation. To insure maximum performance, all Zirgo fans offer reversible blades allowing them to operate as pushers or pullers. Zirgo's revolutionary four point mounting bracket insures easy placement for maximum performance on your vehicles cooling system. All high performance Zirgo fans offer plug-in color coded harnesses resulting in easy installation even for the “weekend” mechanic. All Zirgo high performance cooling fans are tested several times for maximum performance and operation. By the time the Zirgo fan reaches your door you can be assured of a long life of quick, quite, and smooth operation. Zirgo's ultra thin design and unmatchable performance, along with a limited lifetime warranty, make Zirgo the optimal fan for the ultimate vehicle. For unbeatable heat, fight back with Zirgo's strongest motors! Zirgo's unique revolutionary motor designs offer low amp draw, while providing future performance upgrades. To insure peak performance Zirgo's easy to remove motor allows you to upgrade or exchange your motor in the future. Simply remove 4 screws, insert the new motor, and your done! Let Zirgo high performance cooling fans cool you down, when you heat up! [​IMG]
  7. Rick Book
    Rick Book Member
    Thailand
  8. 71gold
    ..." :cool: er"
    ..." :cool: est" :yup:
  9. 71gold
    o.k. update....
    the bad a$$ fan ...sucked...big time...:yup:
    it was bad when i took it out of the box..it had no more CFMs than the ...2000 CFM...fan i took off (plug them in off the car). it had a short in the main wire to the motor. it would shut off and i had to wiggle the motor wire to get it to come back on....found this out when the temp went to
    215 degrees :whew: going to town to try it out in stop and go driving.
    maybe they are as good as advertised but i want buy another one to see...($251 to my door).
    so Mike and i went to Summit yesterday and returned it. i now have my stock v8 fan on...i will see today what temps it runs.
    ...:bouncy: ...
  10. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I thought it was good for a fan to suck? :huh: :p
    Isn't that the fan that you have Allan?
  11. 72MAVGRABHER
    Roanoke, Va.
    Summit has a perma cool, i believe, 16" that pulls like 10amps or something relatively low... it has lightweight aluminum blades and long life high speed bearings in it. It produces 2,950 cfm.
    it's like 119 in the catalog. great for a puller.:thumbs2:
  12. scooper77515
    starting at $35+shipping from ebay...various sizes, various CFMs.
  13. 71gold
    i took a ride today...rode the interstate for about 4 hrs.went downtown for 2 hrs. the temp reached 183 degrees at one point ,most of the time 175 degrees...A/C chilling (y)
    stock 3 row radiator...A/C...trans cooler...stock v8 fan
    ...:cool: ...
  14. 71gold
    anyone running these on an A/C ..auto.trans. car :huh:
    ...:cool: ...
  15. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    electric fan
    Throw some airplane wings on that car and it will probablly take flight....:biglaugh:
