Electric fan relay/temp sensor/temp gauge?????
Discussion in 'General Maverick/Comet' started by Richard Kuss, Dec 16, 2016.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    Finishing up my electric fan relay conversion. New problem. I have the relay wire and temp gauge wire to temp sensor. If both are connected to sensor. I can turn the fan on with key off, by a switch. But it won't shut off. I unplugged the relay wire from sensor and fan shuts on and off with key off... any ideas why I can't run both? I followed the schematic as shown.
  2. lowteck101
    lowteck101 Member
    middletown ohio
    1973 maverick 70 torino gt
    I believe the sending unit needs to be the kind the grounds itself to engine block to turn on fan one you have is alway sending to gauge
  3. bmcdaniel
    bmcdaniel Senile Member
    The fan sending unit is just a switch, turns on and off at specific temperatures. Your gauge needs a thermistor type sensor that varies resistance with temperature.
  4. Richard Kuss
    Red Bluff Ca
    I realized that. I'm looking into aftermarket Stat housings that are tapped for sensors
  5. bmcdaniel
    Or you can just put a tee for the gauge sensor in the top radiator hose. Separating the relay from the gauge should take care of your problem.
  6. Richard Kuss
    Red Bluff Ca
    A tee?? and yes I said once I took the rely wire off, it worked fine
  7. modmav
    modmav Member
    Jamestown ND
    get the thermostat housing with the tapped hole and install tour fan switch in it, using a tee could be an air trap
    Richard Kuss likes this.
  8. bmcdaniel
    Air trap? This is how I did mine and it works fine. Earlier I said about putting it in the top radiator hose, I meant to say top heater hose.
    m in sc likes this.
  9. modmav
    modmav Member
    Jamestown ND
    I was picturing a tee on intake for some reason I see now what you did, however I dont see how that would give an accurate temp reading
  10. bmcdaniel
    The water comes from the same place as where the sensor is normally placed, the front of the intake manifold, and the coolant is constantly circulating through the heater. When I added EFI I put the sensor for that in the usual location and moved my gauge sensor to the upper heater hose. The coolant temperature as measured by the EFI display and the gauge are within a few degrees of each other.
  11. Hotrock
    Munroe Falls, Ohio
    You are on the right path. Get the aftermarket stat housing with the sensor provision as modmav suggests. That is what I have and it will fix your problem. It also allows you to exchange temperature sensors to control your electric fan operation.
    I also have the optional cooling fan overide switch mounted under my dash.
  12. Richard Kuss
    Red Bluff Ca
    I ended up ordering this to give it a try. Should solve my problem from what I read and heard online.
  13. Richard Kuss
    Red Bluff Ca
    I looked online for a few hours. Only 90degree one I found with tapped for sensor was the mr.gasket chrome one. Alot of bad reviews on chrome chipping and surface not being flush
  14. Hotrock
    Munroe Falls, Ohio
    Why 90 degree? Our vehicles didn't come with that design of housing. I use the one on the Auto Zone site. Link following.
    http://www.autozone.com/cooling-hea...r-works-water-outlet/141903_0_0?checkfit=true
  15. Richard Kuss
    Red Bluff Ca
