Electrical plug under hood
Discussion in 'Technical' started by rickm, Nov 21, 2010.
  1. rickm
    rickm Member
    Owosso Mi
    I'm pulling everything in the engine compartment for a paint job. How do I remove the wiring plug next to the M/C ? I removed all the brake lines and M/C and now need to get the wiring out of the way. I'm going with a semi-flat black can anyone that has done this tell me what brand of paint they used ? Thanks Rick
  2. Craig Selvey
    You have to loosen the bolt on the other side. It is located right in the middle of the fuse box. Loosen bolt, pull fuse box out of the way, squeeze tabs and push wiring harness out of firewall.
  3. rickm
    rickm Member
    Owosso Mi
    Thanks Craig I'll give it a try in the morning.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I never knew that ... I just masked mine off ...
  5. Dave B
    Òh My...-10 points!!! :rolleyes:
  6. justin has a 74
    kentucky
    :D
    Alright i'm getting out of here before i get in trouble:outtahere:
  7. rickm
    rickm Member
    Owosso Mi
    Craig it came right off, but now I have to put it all together again.
