Electronic distributor question
Discussion in 'Technical' started by agent281, Aug 13, 2010.
  1. agent281
    agent281 Member
    murray ky
    1974 maverick inline 6
    well I've been looking into converting to an electronic distributor, but there seems to be about a billion ways to do it and I can't really find what I'm looking for.
    I saw the petronix system, what would be the difference between doing that or putting an HEI distributor on it? Also, is there a specific one I need or can I just get one off a later model 302 from a scrap yard?
    I'm under the impression its going to make a world of difference converting from a points system. Is this true?
    Thanks!
  2. Earl Branham
    Lugoff, SC
    Yes! No more adjusting and replacing points, and the car will drun a lot better. The Pertronix kit is the easiest, only two wires to hook up, or a billet distributor (MSD, Summit, Accel or many others) is also an easy conversion. The DuraSpark is good, but a bit more difficult to hook up. Good luck!
  3. idrivemav
    idrivemav Member
    texas
    1975 maverick
    i have a dui hei in my car it runs very good if you go that route dont hook up the vacuum advance it makes the timing jump around and makes it impossible to time and it runs bad
  4. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    My HEI runs great, vacuum advance and all...
  5. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    any system you feel you can handle putting on will be a vast improvement over points.
    I personally like the billet distributor option. Clean and easy to install and upgradable in the future. I ran the accel dist until I wanted a rev limiter. So then, I installed the accel 300+ box and coil using the pick up from the billet dist.
    Pertronix is quick and easy. Usually has good results and would be my second option if I didn't want to spend the cash on a whole distributor.
  6. rthomas771
    Duraspark is a 2-wire hookup also. The extra wires is in the harness going from the box to the distributor.
  7. Bob Wiken
    Fayetteville, Arkansas
    Does anybody know off hand what the part # for the pertronix is? (302 roller motor)
