Electronic Ignition
Discussion in 'Technical' started by Mav Rick, Nov 28, 2006.
  1. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    I was thinking about putting in an electronic ignition, but before I do, I want to know what you guys think... good - bad - and everything in between.
    I have heard they can be really beneficial, but could lead to more problems...
    Any infomation would help. If anyone knows about how much I could do this for and how difficult it might be, let me know.
    Thanks!
  2. rayzorsharp
    Unless you're looking for serious performance gains, I'd go buy a Pertronix kit from the parts house. It goes in your existing distributor in place of your points and makes a tremendous improvement. It's also very trouble free and only about $80 and very easy to install.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    YUP electronic is WAY better than points (y)
  4. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I also vote for Pertronix.
  5. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Awesome... thanks guys! thats a huge help!!
    I was also thinking about putting a new distributer in because I think mine is still the original... kinda wobbly.
    I had some major issues with my car misfiring a few weeks back to the point I couldnt drive it for 2 weeks. I just got it fixed this past weekend with getting the timing straight, new plug wires and such. It is running now but not like it use to... still a little shaky. I was thinking about the elec. ignition and mabe a whole new distributer would do the trick, especially if the old one is going bad. EVERYTHING else with tune up has been done, so why not go all out...
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I converted from points to Duraspark-II electronic ignition back in '93, and have never had any trouble whatsoever with it ...
  7. bmcdaniel
    I'm using an Accel Blueprint distributor with a Pertronix module. The Blueprint uses a stock housing but with better bushings and parts inside and adjustable vacuum advance can.
