eliminating a/c i6
Discussion in 'Technical' started by 66170MAV, Oct 30, 2010.
  1. 66170MAV
    66170MAV Member
    Lancaster Ca,
    Trick of Treat!...
    Hello everyone..
    Ive recently took my i6 200ci head in to get a valve job and while I have the time, I figured ill do some cleaning, painting and replacing.. To make it short, I decided to remove the entire ac system for a cleaner stripped down look under the hood.. The problem I have now is this huge cast mount that held the compressor also holds the alternator... Ive called auto part stores in my area in search of the proper bracket, but no luck.. All the pick a parts around here dont have anything older then 1985 to pull from... Is there a wed site I can maybe get a deal on this?.. Some one had to have gone through this too.. Also if I cant fide the bracket, what size v-belt works after eliminating the ac compressor but still using the huge ac mount to hold the alternator?... Thanks
