engine accessory brackets
Discussion in 'Technical' started by EFIMAV, Mar 19, 2007.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    OK, I'm using newer 5.0 heads with the AIR injection threaded holes on the front and back of the heads. I can buy threaded plugs to block them off but I need to use one on the driver side front for accessory brackets. My problem! The threaded hole is larger than the bolt that holds the bracket on. Is there an insert that I can use to reduce the size of the threads to match the bolt? Thanks.
  2. baddad457
    Yea, there's a threaded insert for that hole. The dealer should have these. If not, let me know and I'll pull one and mail it to you.
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    All the ones I have seen had the threaded insert on one end and open on the other.
  4. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    A Company Makes Them Called Silver Seal Part#6556
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Ford part number
    F4ZZ-6E086-A
  6. Maverick Man
    California
    summits got them too. i used them in my dart heads... ford dealers gonna have to order them i bet!
  7. NAFORD302
    NAFORD302 Member
    SILEX MO
    most ford dealer have them on hand i have got them from 2 differnt dealers
  8. maverick1970
    Missouri
    Dealer had them in stock when I needed them also.
  9. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Thanks
    I called the dealer today and they said no deal. But, with the part number I may try again!!
  10. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Well, I called the dealership with the above part number and they couldn't find it!!
  11. baddad457
    Ask to talk with the parts manager. You could be talking with someone who's still wet behind the ears.
  12. maverick1970
    Missouri
    I made a mistake and gave the wrong Ford part number. It has been corrected in my previous post.
  13. EFIMAV
    EFIMAV Member
    Davenport Iowa
    found correct number
    Well, after calling FRPP and reading MAV1970s post I called my local dealer. They can order the part for 21.97 each. And, they come in pairs for a grand total of 43.94 plus tax! I talked them down to 16 a piece! What a steal! Anyone have any idea why FMC isn't doing so well? Makes me want to run out a buy a Ford! NAFORD302 I called silver seal and they have them for 99 cents. Imagine that! I'm sorry for the sarcastic tone but that pricing is simply stupid.
  14. maverick1970
    Missouri
    Wow, were they trying to stick it to you. I know I didn't pay more than a couple of bucks when I last bought them.
  15. mavtricks71
    mavtricks71 Member
    air injection? i have 94 5.0 motor, are you talking about where egr tubes connected on back of the head? i just threaded bolts in there...is that bad????
