Engine and Tranny wont come apart
Discussion in 'Technical' started by cardstars, Aug 1, 2009.
  1. cardstars
    cardstars Member
    Minneapolis
    Am I missing something? I got them about an inch apart and now they wont budge. Do I just need to pry harder? I didnt dare go much harder with the crowbar cause I was worried I would break something. I have a 302 and c4
  2. tonyj71mav
    tonyj71mav Member
    Upper Marlboro, Maryland
    Have you removed the 2 bolts that are near the fly wheel inspection plate. Bolts are below the starter and face the opposite side of your transmission to engine bolts at the bottom.
  3. Earl Branham
    Lugoff, SC
    Did you remove the converter bolts?
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Should be the 2 bolts on the starter. 6 on the bellhousing and 4 holding the converter to the flexplate. I assume you have already disconnected the vacuum lines, cooler lines, linkage, mount and removed the driveshaft.
  5. starsky74
    starsky74 Technician
    Hackberry Louisiana
    sounds like converter nuts to me:cool:
  6. blugene
    Driveshaft!? :rofl2:
    I think either starter or inspection cover. Could be crossmember.
  7. don graham
    My vote is the convertor bolts too. Starter bolts would not let you get it an inch apart. TQ would.:)
  8. yellow75
    Tillamook Oregon
    My vote is inspection plate bolts, should be able to pull it off of the torque convertor
  9. don graham
    I agree Mike, unless the TQ gets cocked a bit. :)
  10. cardstars
    cardstars Member
    Minneapolis
    aha - so I see there are 4 bolts in there connecting the flywheel to the torque converter? I managed to get 3 of them off but the 4th is of course on the bottom, which is on the ground. Ill get her though - thanks for the help guys
  11. don graham
    yep, 4 bolts.:)
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    +1
    after finding out it is sitting on the ground I am assuming that he did not take off the inspection plate before he set it on the ground so even if he took the torq converter off he would not be able to get the tranny and motor seperated.
  13. 71gold
    how did you get 3 and can't get the 4th...:huh:...didn't you turn the flywheel to get the 3?
  14. 71gold
    ...agree...(y)
  15. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I have pulled a tranny apart from the engine without removing the torque converter bolts but it was several years ago. The 351C 4V was locked up due to a broken camshaft. I did of course pull the bolts for the spacer.
    What a pain it was getting them apart though.
    clint
