Engine Bay Dress Up
Discussion in 'Cosmetic' started by cardstars, Jul 27, 2009.
  1. cardstars
    cardstars Member
    Minneapolis
    So I just pulled the engine and tranny out of 71 gt today and thought this would be a good time to attempt and dress up the engine bay. I know nothing about body work - so I figured I would ask the forum what the best way to go about this is? Is there any good spray paint out there to make it look halfway decent? And should I just go over the bay with a sand block to rough it up? Im obviously not looking for show car stuff here, just something to make it look a bit better. Any help is greatly appreciated!
    BTW - I saw the original paint codes in another thread but I dont have a sprayer
  2. cardstars
    cardstars Member
    Minneapolis
    I should mention that right now im thinking I should borrow a friends pressure washer to go through there. Any info on a good spray paint that will look good in the engine bay? Or are most spray paints going to chip away in no time....?
  3. Joe Dirt
    degrease and pressure wash good,get a scotch brite pad and scuff it all down
    and topcoat with a semi gloss black
    professional series rustoleum semi gloss leaves a nice finish and is pretty durable my truck is done with it been that way for over a year and still cleans up nice (only the frame is done in this pic)
  4. maverick maniac
    maverick maniac Banned
    owensboro ky
    yes that is what i was going to say
  5. mercgt73
    mercgt73 Member
    Rustoleum is nice, it has a mild primer built in. I made a mistake on my first Comet resto and used Krylon spray paint, which is water based. Bad idea, it was peeling within months and could not handle the heat in the engine compartment.
    But Ive heard of others using Krylon, so it could have been my prep. I think Rustoleum is the way to go, its durable and also pretty forgiving.
  6. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    here is what I did. After engine and trans pulled, fasten wiring harness up to wipers to get it outta the way. go to a cheap store and buy 5-6 cans of oven cleaner. wash off all lose dirt and then spray all engine compartment with oven cleaner and let soak for about 2 hours. rince with power washer and repeat first step. let soak again for 2 hours( do not let it dry) rince and check to make sure all grease and oil is gone, especially in small corners or tight spots.(Now you have used 4 cans). If not repeat a 3rd time. rince off with soapy water, then clear hot water if you can, and then blow dry with air pressure.Let dry over night. Sand with 220 paper by hand and make sure you miss no spots.blow off dust, wipe with laquer thinners and then let dry over nite. Tack in the mornin and I painted mine with self etchining EPOXY paint from VHT(rattle cans), about 10 gives 2 good coats). I used satin black for mine but it comes in many colors. I did mine 3 years ago and is still looks great today. I rince it off with clear water or soapy water first if need ed for dirt , then just wipe dry with a old towel. looks great all the time. Hope it works for you.RON:D
  7. cardstars
    cardstars Member
    Minneapolis
    Wow thanks guys! I am actually thinking about painting it white now (color of the car). I know I can order the exact paint in a rattle can online - but I wonder if it can withstand heat in the engine bay?
    Black would be the easiest but white would look oh so good in there.
  8. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    This may not be true of all Rustoleum paints, but I know many of them don't take well to contact with gasoline. Just something to keep in mind.
  9. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    i used degreaser, a scotch brite pad, and VHT Chassis Paint (Semi Gloss Black)
    sorry no pic :(
  10. cardstars
    cardstars Member
    Minneapolis
    10 of them??!?!?
    **** I would have guessed 3-4 tops
  11. rayzorsharp
    I'm all for body color but just keep in mind that for a driver you are going to have a helluva time keeping it clean if you go white.
  12. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    mine was brown and undercoat overspray. i just used a spiral saw with wire wheel and removed the undercoating. then I sanded with 220, down to 800. I sprayed high heat gloss black (3 cans) and sprayed engine, put everything back and it looks 10 times better. For about $30-$40 (y) mine gets compliments from everybody who looks at it. I don't have a big budget cause I'm still in High school but black compartment with ford blue engine turned out good for a budget paint job and looks close to original.
    -1st time you drive it in rain a white engine bay will look dirty :cry: unless you garage keep it and baby it.
  13. ed1224
    ed1224 Member
    florida
    72 MaVericK
    i have a set of fenders off of a 74 im looking to sell them
    maverick
  14. Turner327
    Turner327 Member
    Phoenix AZ
    1973 Comet
  15. Mavaholic
    A white engine bay looks great!!! Just have to clean it more often.
