Engine bay overhaul (Pic heavy)
Discussion in 'Cosmetic' started by b_ryce70Mav, Sep 24, 2011.
  1. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    The engine was more or less running fine when I got this car. All I did mechanically was carb rebuild, header swap, intake swap, and various minor things. The engine bay was hideous though, and I was getting tired of looking at it and wanted to get my T-5 swapped in as well. My goal was to make the engine bay as clean as possible with no clutter, just a showcase for the engine.
    This is my fair weather fun car, and everything is built to be simple and easy to work on, to include the engine bay. If it wasn't necessary it was removed, if it was necessary it was moved to where I wanted it.
    Before....ewwww
    Empty
    Some of the last remaining cancer
    I think the previous owner dropped it off a jack, or ran over a warthog.
    The worst part of this being beat so bad is that its where the jackstands go, and it was difficult to get the jackstands stable with it being so un-even so...
    A little diamond plate and some welding....
    Much better
    Patching patching and more patching
    No more rust. The nails are all filler for old bolt holes.
    More patching
    This should free up some room for a future 351W :burnout:
    Thats gonna need some welding
    All welded up
    Mmmmmhh paint....
    Engine cleaned up and reassembled minus the ugly cheapo valve covers
    Previous owner thrashed the trans hump, so away it goes
    In it goes....
    Bolt in, relax, celebrate
    Factory wiring loom chopped apart into separate sections to go where I want them. headlight bundle under the fender, engine bundle along firewall and bolted to intake, solenoid bundle to shock tower opposite master cylinder.
    All done to include custom fabbed shock tower braces and monte carlo bar. 1 1/4" thick wall steel tube
    One more shot of the braces. Little bit more secure firewall mount than the factory stamped steel
    Champion 3 core radiator and low profile fan on thermostatic switch.
    One last glamour shot
    Here's where the solenoid and all the wiring went.
    Battery holder not fabricated by me. Unfortunately I don't own a water jet CNC machine.
    Temporary shifter setup until I fab a new one, Lotus Elise pedals.
    Pinto handbrake w/ Lokar cable kit. A bit more functional than the under the dash factory handle.
  2. Dave B
    Looks awesome! Nice work!
  3. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    I am available next weekend, when can you come over. I already have the motors pulled from 72 Grabber and 72 Comet Gt.
    On a serious note, Great work !!!:bananaman
    Rick
  4. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Oh I am. Summer is running out, so I just went out and found some back roads that looked like they could use some fresh rubber :burnout:
  5. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Unfortunately it will just be one tire until I get some sort of locker setup for my rear.
  6. 464925
    In my Mav.
    Maverick 1973-Pure Muscle.
    Nice
    Really nice. Wow...
    I would like to do that with my Mav.
    Nice work man.
  7. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Thanks, it really wasn't too hard. As long as you own a welder.
  8. mav1970
    Wow, you really took care of business - nice job :thumbs2:
  9. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Very Nice Work! Wow! (y)
    I like the beer bottle level test pic...hahahha!
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Looks much better, nice job..... :drive:
  11. mojo
    Nice work~ Like the hump mount brake setup.
    Might want to give some more details or a tech writeup. I need to do my em/park sys.
  12. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I completely intended to, and then I got carried away on the install and forgot to take pics. I will probably do a write up at sometime but what I can tell you is the Lokar kit is fantastic. I just bought the cables with no handle and modified a Pinto handle to work. The Lokar kit (mine was actually a cheaper rebranded one with the exact same parts from ebay) comes with the cables with ball ends, sleeves, cable guides and mount. Very very easy install.
  13. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I am truly inspired. You "Rocked It" Bro!:party3:
  14. Thrashin302
    Thrashin302 Member
    South Dakota
    great lookin car
  15. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Awesome job!!:thumbs2: Everything tastefully done. Do you know what color you are going to paint it? That engine bay, as nice as you made it, needs color on it, shiney color that is.
