engine clearances
Discussion in 'Technical' started by rolandag2, Mar 4, 2007.
  1. rolandag2
    rolandag2 Member
    Dickinson, TX
    1970 Maverick Grabber
    i have 88 302 efi h.o engine and would like to know the clearances for main and rod I plan on running the motor on the strip occassionally but mainly i will drive it on the street maybe some nos but a little not no massive amounts of it.:dance:
  2. bmcdaniel
    I like to run .0020-.0025 on the mains and rods, except the #1 main I try to get closer to .0015 for better oil pressure. I'm sure others here will have their own specs.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    this is kinda off topic but would clearences be different if your running n2o or turbo/s/c?
  4. bmcdaniel
    Can't comment on the turbo or s/c applications but the above is what I ran in my old N2O motor. Bearings generally like more clearance for more rpm, open up the clearances for sustained high rpm and you should consider running a HV oil pump and a bigger pan.
