engine crossmember location?
Discussion in 'Technical' started by Maverick_Matt72, Jun 24, 2008.
  1. Maverick_Matt72
    Maverick_Matt72 Member
    Deep In The Heart Of, Texas
    '69.5 Maverick
    Anyone have pics of where the engine crossmember is supposed to bolt?
    I have a 69.5, and I know that these never came with v8s. Thus, I figured that maybe the reason I couldnt find any damn place that it would go, that my car didn't come with the mounting holes.
    I have a stock maverick engine crossmember that I bought along with the frame stands and tranny crossmember, so it should fall right in there... somewhere...
  2. newtoford
    newtoford Member
    New Castle Delaware
    if you look on the frame where the "sockets" are that the lower controll arms bolt into, its on the frame right behind them. should be a threaded hole on each side. but like you said, 69.5's would have no reason to have these holes already predrilled so you may not find a factory location to bolt it to.
    i thought it actually tied into the frame mounts. if you run a search i started a thread a few weeks ago about trying to get that crossmember into my '76
    good luck
  3. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    My 69.5 has them.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    My 70 has them. The holes will be on the bottom side of the frame rails. The cross member fits just ahead of the steering drag link.
  5. rthomas771
    Here is a shot from my 72 V8 parts car.
  6. bmcdaniel
    Hijack...
    I need the special cone-shaped bolts to install mine.
    End hijack.
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  8. bmcdaniel
    Makes sense. Thanks! :tiphat:
  9. Maverick_Matt72
    '69.5 Maverick
    Thank you guys!
