Engine electrical wirening?
Discussion in 'Technical' started by benben, Jul 13, 2007.
  1. benben
    benben Member
    Europe, Estonia, Tallinn
    Mav`75, 302, 2d, A/T, A/C
    Hi!
    Lost the spark. Where I can find the engine electrical scheme ´75 Maverick. And the measurements of restriction(how many ohm ect.) Everybody else is on the biggest US cars meeting in my country , and I'm sitting at the friends garage, car is dead...
    Help!
  2. PaulS
    Some quick checks for you.
    check the coil connections
    check the points
    check power to the coil
    check fuses
    check ground straps
  3. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    check the electronic control module !!!!
  4. benben
    benben Member
    The problem was burned wire from coil to distributor, I elliminate electronic ignition,( still do'nt no wats burned out) put the older type distributor from '69 Mustang with 302(but without contacts, with pick up coil, and ignition coil) and problem sold. Thanks to comments.
