Engine is in !!!
Discussion in 'General Maverick/Comet' started by MiteeMaverick, Feb 17, 2005.
  1. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    Well I got the 302 in yesterday, I wound up stabbing the engine and tranny in together; much easier. I had a few problems, had to trim the double hump tranny crossmember for my 69.5, also the torque converter didn't match my flexplate, had to get a 164 tooth flexplate, but all in all it was a breeze and my help bailed on me so I had it all by myself. I still have to put all the fluids in and buy a starter. Oh buy the way the Tri-Y headers are a breeze to install, you can almost throw them in, although I had to massage 1 tube, the steering arm was rubbing it. I will get some pics out this evening. :)
  2. don graham
    wtg. i also had to play the match game with the flexplate. i now have both size flexplates and convertors and bellhousings. $$$$$$$:) also have pre 1970 trannys and later c-4's also.
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
  4. Jamie Miles
    Awesome! Can't wait to see pics.
    Man I know how them flex plates are. Been in the process of swapping out my blown 360 in my F-250, bent the flexplate while lifting the engine out. Man, you wouldn't believe how hard it is to find a flex plate for an old 360! Been to about 8 junkyards in NC, GA, AL and SC without luck.
  5. MiteeMaverick
    Jonesboro, AR
    She breathes fire
    She turned over 3 times and came to life ! Man does it sound awsome with open headers !!!! It actually raises the front end when I take off, I forgot how much power a V-8 has in a light car.......it's been about 10 years since I had a V-8, especially one with 300 HP. This swap was really easy after all the parts hunting, I figured it would be a nightmare going in but I really had no other problems other than the ones listed above. The cam was a perfect pick, not too lopey but plenty of power, I guess the ported heads probably doesn't hurt either. Now I need to descide on exhaust, thinking about just regular turbo mufflers, I had Flows on my 87 Mustang but it was too loud. Any suggestions? :bananaman :bananaman :bananaman
  6. Timsm
    Timsm Member
    Spokane, WA
    69.5 Maverick
    Do the tri-y headers work with your column shifter or are you going to have to put it on the floor?
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I was thinking about Tri-Y's when I built my Grabber but was afraid they wouldn't clear the Manual Tranny z-bar and linkage ..
  8. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Congrats on transplant!!!
  9. tim keck
    sharps chapel,Tn
    I like Dynomax,reasonably priced & a mellow tone.
