Engine problems
Discussion in 'Technical' started by madbaverick, Jun 9, 2009.
  1. madbaverick
    madbaverick Member
    broken Arrow, OK
    1973 2-door Maverick, 1977 2-door Maverick
    Hey guys I am need on any ideas about my car. Here is the problem
    the engine is consuming a huge amount of oil. Like a 1/2 quart per
    tank of gas. Most is comming out of the spark plugs. ( yes I mean
    literaley bubbling out of the base of the plugs while running but only
    from number 1 and 4 cylinders). I assume it is burning some of the oil becouse those two plugs keep fouling even though the engine doesn't smoke much. Any ideas? I am thinking maybe something with the head
    or head gasket? Anyone ever experienced this?
    The engine is a 1977 250 6 cyl. that was supposed to have been rebuilt. I know it was apart becouse i have pics of the block out of the car and bare, but I do not know if any head work was done.
    Thanks for any help.
    Cary
  2. rthomas771
    Sounds like valve seals gone bad. They can be changed without removing the head.
  3. madbaverick
    madbaverick Member
    broken Arrow, OK
    Is there a way to test if this is the problem?
    How hard to replace the seals? Any special
    tools needed?
  4. Bryant
    i find it hard to belive that oil is coming through the spark pulgs. im sure any thing is possible but it suspect that the oil bubbling on the plugs is driping from the valve cover. the excesive oil consumption could be caused by several things. if the pcv valve is bad the motor will smoke alot and burn alot of oil. (it should smoke alot using that much oil anyways) the valve stem seal as mentioned, or the rings on the pistons. the pcv valve is cheap and easy so start with that. a compression test will show bad rings, so i would do that next. if the compression tests good on all cylinders then the valve seals are your most likely culprit.
  5. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    +1
    Check your valve covers...
  6. madbaverick
    madbaverick Member
    broken Arrow, OK
    I wish it was the valve cover! I wouldn't have your wasted time
    for that. Valve cover gasket has been replaced and the head is
    dry above the two problem spark plug holes, plus a leaky valve
    cover wouldn't foul the plugs in those two cylinders. I am hoping
    for a compression test this weekend. I guess my biggest fear is
    a cracked head. I know there have to be some oil passages in the
    head somewhere. I just can't imagine why I would have that much
    liquid oil in the cylinders to make it bubble out like that, even if the
    plugs are allowing some compression to escape. Oh, and it still isn't
    smoking! :hmmm:
    My hope with posting this was that maybe some one else had some
    experience with this problem.
    Thanks
    Cary
  7. Rando76
    Rando76 Member
    Claremore, OK
    I've seen this in person and can back him up. He first thought it was a valve cover gasket and changed it. It gets the base of the plugs covered in oil while everything above it is dry. It's weird. Funny thing about it all is that I have never seen this car smoke. I figured if it were valve seals it would smoke (atleast a little bit).
    I've had PCV valves go bad and cause oil burning, but not specific to two cylinders and never causing oil to puddle around the plugs. I'm not arguing that these aren't good ideas, just that he's already been down that road. :yup:
  8. madbaverick
    madbaverick Member
    broken Arrow, OK
    update
    OK guys I pulled the head after doing a compression test which came
    out fine. Took the head to a machine shop known for expertise with
    Ford engines. They said I need new valves,guides and seals, the seats
    are questionable. Cost if they can ground the seats is $460.00. More if
    I need new seats. Also the springs are weak. I can't see spending that
    much on a 6 cylinder head. My question is is there any difference between
    a 250 and the other 6 cylinders? I know where I can get a running 170 or
    200 6 cylinder for free. Should I do that or just v-8 the car? I have all
    the parts on my '73 but I really don't want to strip that car to build the
    '77. Decisions,decisions,decisions!:banghead:
  9. PaulS
    The 200 head will give you higher compression but smaller valves and intake log.
    It also takes a different carb/adapter.
  10. 71gold
    if it's a running 170 or 200 6 cylinder, get the carb also.
    i ran a 170 head on my (nowTerrys) 250...:yup:
    ...Frank...:drive:
