Engine starts when I disconnect spark plug wire
Discussion in 'Technical' started by downhillbiker, Feb 17, 2012.
  1. downhillbiker
    downhillbiker Member
    Salt Lake City, UT
    1976 Stallion/Grabber
    There has been two occasions when my car just cranks and won't start. It's getting gas I can smell it. Both times I pulled the front driver side plug wire and set it close to ground to check spark and the engine fires right up. What would cause this?
  2. 71gold
    vapor locked or flooded...it sat long enough to cool/dry out...:yup:
  3. baddad457
    Do you have a ground wire directly from the engine block to the battery or frame ? One of these locations would be good, both wouldn't hurt either.
  4. downhillbiker
    Salt Lake City, UT
    I know there is ground from battery down, but not sure where it connects. I will double check that. Might run one from the frame to block. One of the guys at work was questioning a ground issue, since that is essentially what I was doing with the wire.
  5. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Sounds like the ignition module is going bad. I use to take the distributor cap off, say hi to the insides, replace the cap and car would always start.
  6. 71gold
    are you using the engine or some part of it to ground the wire?
  7. darren
    By doing that your forcing the coil to jump a larger than normal gap. Coil goes to max output. Keep that in mind. You could be dealing with an ignition issue. Bad plugs/flooded plugs/bad wires etc. Tough to diag on the net but food for though I guess.
  8. 71gold
    I've seen people pull the coil wire out and let it arc into the cap. they say it gives a hotter fire to dry flooded plugs...
    ...:yup:...
