Engine swap problems
Discussion in 'General Maverick/Comet' started by Aussie, Oct 20, 2018.
  1. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Gday folks how are you all. I have a 1973 Ford Maverick here in Australia and i believe it was born a 6 cylinder and now has a 302 windsor with AOD transmission which i think was out of a Foxbody Mustang. It was imported to australia with all this done. Problem i have is when it revs the distributor retards instead of advances. Can anyone help me please. What needs changing and where can i find it.
    Cheers
  2. Krazy Comet
    Whadya 'spect? You're upside down. ;)
    Need to know more about your setup, does it have a dual diaphragm dist? How is vacuum to dist plumbed?
    BTW welcome.
    CaptainComet and Hotrock like this.
  3. 71gold
    :Welcome:...:Handshake:
    I agree with Krazy on the ...upside down thing...LOL
  4. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Thanks fellas by the way you steering wheels are on the wrong side of the car LOL. Ok there is no mechanical advance or vacuum advance. 20181021_121855.jpg 20181021_121924.jpg 20181021_121936.jpg Here is what i have
  5. Krazy Comet
    Ahhh, that's a dist used with EEC-IV systems, has no advance. Normally the computer advances timing dependant on load, RPM, temp etc.
    You are going to have to get either a Duraspark dist and module, or go with a aftermarket electronic dist of your choice. If you have a points dist for 302, it can be used to trigger the TFI module that's on the EEC dist.
    BTW whatever dist you use it MUST have a steel(or bronze) gear to be compatible with the roller cam used in HO 5.0. The cast gears on std dist will be destroyed in 5-8K miles, spewing metal bits throughout the engine.
    Maverocket likes this.
  6. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Thanks mate your a champion. I will let you know how i go.
  7. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    We need to know if your Car has a EEC System Computer. There is another new,universal Dist. Gear . It should be a carbon fiber Gear, From sumitt Parts ,100 dollars for the gear
  8. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Thanks mate. I am waiting on a duraspark distributor to come. I reckon that will fix it.
  9. Aussie
    Aussie Member
    Australia
    1973 Maverick
    Krazy Comet thanks for the advice. Mate this car of mine flys now. It is like a different car now. Hard part now is to drive to the speed limit.
    Thanks again.
    Maverocket, Krazy Comet and JoeB like this.
