Engine that been sitting for 4-5 years
Discussion in 'Technical' started by Zachary74comet, Dec 29, 2004.
  1. Zachary74comet
    Zachary74comet New Member
    muskogee,oklahoma
    1974 comet
    I have a 1974 comet that has just been sitting outside...how should i go about getting the engine to run.
  2. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    mine sat for 2 years before I got it and a few of my seals were bad. I have a lot of hoses too... I had to replace fuel hose that goes to carb and top rad. hose cause they were cracked. Ya don't want gas leaking anywhere :p Oil and gas are probably old and crappy too. Wouldn't hurt to drain gas tank and change oil. I'm not sure about the tranny i've been told to change it by some others told not to so i haven't done it. I'm sure your'll get a lot more from other people but thats just some basic stuff to get ya started and pretty cheap too.
  3. Earl Branham
    Lugoff, SC
    Matt; the engine in my car sat for 10yrs in a friends back yard, and when I got my Mav, he said he would sell it to me ('74 Comet). It is a 302, and I did the following to get it going: 1) change all hoses and belts. 2) change points and coil, or convert to electronic. 3) Remove the plugs, put oil in the cylinders, and turn the crank with a breaker bar or wrench. If it turns well, keep turning it a few times, and let the oil seep into the rings, and CHANGE THE OIL! 4) Install new plugs, rebuild or replace the carb. 5) Check out the wiring, and install new plug wires. 6) Drain gas from the tank, check for rust and crud in the tank. Clean the tank and put in good gas, check all the fuel lines and install a new fuel filter. 7) Install a good battery, turn it over and see how good it runs. It will smoke a bit from the oil in the cylinders, so don't be impatient. Mine smoked for a week, and one day it quit, and has been perfect since. Good luck, and let us know how you make out.
  4. 71gold
    " all the above "... plus i would take a drill and spin the oil pump to get oil to the top end before cranking...frank...
  5. Earl Branham
    Lugoff, SC
    Frank.....forgot that one!
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    I got bored with mine(read married with kids) and let it sit for 9 yrs.. No oil, no prespinning. just pulled the heads replaced the head gasketes and fired it up. Amazing it ran, and still runs today. I did change theoil at 100 miles and again at 300 miles.. No problems... Scotty P
  7. Kilg0re
    Kilg0re Doh!
    Keep in touch and let us know how everything turns out bud! Got any pics also?
  8. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    yeah what everybody said.... only difference as far as i am concerned, i usually crank the motor over with the plugs out until the oil light goes out.
  9. Zachary74comet
    muskogee,oklahoma
    1974 comet
    Yeah ill keep u all posted...i havent gott any pics right now but here in a few days maybe ill have some hopefully
    Thanks for the info just waiting on a pay check to come in so i can go get the stuff to get her running
  10. 71maverick
    71maverick Member
    Moline, IL
    Im going through the same thing with my 55 Olds, its been sitting for 13 years.
    http://www.quadcitiescruisers.org/images/projects/1955-Oldsmobile.jpg
    One other thing you might want to check is the front-end, make sure the rubber is in tact and is not cracked, and theat it is lubed well. Also check the braking system, master cyl, wheel cyl, brake shoes and hoses.
    Glen
