Engine turns slow, then gets faster. Any Ideas?
Discussion in 'Technical' started by ryanb, Jan 26, 2011.
  1. ryanb
    ryanb Member
    Portland, Oregon
    '72 2D Maverick, '85 F150 Short Wide, '07 Husqvarna SMR450, 2015 Yama FZ09
    I bought a freshly rebuilt 302 a while back and I dropped it into my maverick. It starts fine when it's cold but when the engine warms up it turns over really slow, then after a couple seconds it starts turning over faster. I don't know much about this engine, but it runs fine, and even when it does turn over slowly it starts up ok. Could it have to do with the compression ratio? Is it an ignition problem? It's got a pretty fresh starter, solenoid, cables, and it's got a good ground connection. The battery is fully charged, soon I'll be swapping in an optima. Does anyone have any idea what it could be?
    Thanks in advance,
    Ryan
  2. Mavman72
    Sounds like over advanced timing or heat soak into the starter/ Check your battery cable connections as well...
  3. 71gold
    X2...:yup:
  4. darren
    Pete beat me again. :huh: first thought was hot starter. Like Pete said bad connections can do that also.:):)
    You may need a heat shield on the starter.
  5. Bryant
    another vote for over advance timing. what is it set to? at idle and at 3000 rpm
  6. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Thats what mine does too! Lol but I knew why already I need to get a heat sheild for my starter at work
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    not sure why but alot of mustangs do that cold or hot
    dont you think it could be that it gets easier because it's got the motor turning as fast as it can go after the first second or two ?
    i know when you have the timing to far advanced and the motors hot it wont want to turn much at all ?
  8. Streamliner
    Streamliner Member
    yep on the timing but a fresh motor will also be somewhat "tighter". especially when hot until things break in
  9. baddad457
    A starter with weak field coils will also do that. You say "fresh starter" as in freshly rebuilt ? Rebuilders seldom ever change the field coils and that's the most important thing to change. The hotter they get, the slower the starter will turn the motor
  10. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    we need to know what comp ratio and what starter. :huh:
  11. injectedmav
    injectedmav Member
    Georgia
    worn starter brushes and armature/drive end bushings are a possibility as well in addition to above. don't overlook the ground side. too many times have I seen a 2 or 4ga feed wire and a 6ga or smaller ground or one with bad connections.
