engine vin number location
Discussion in 'Technical' started by coutangman, Nov 3, 2009.
  1. coutangman
    coutangman Member
    Charlotte, NC
    I have been trying to lacate the vin number location on a 302. I know where it is on a 351, but have not been able to locate it on a 302. I have a 289 out of a '67 Cougar, a 302 out of a '72 Comet, and another one out of an '83 Cougar. Can anyone help?
    Jim
  2. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    there is a flat spot on block at the rear of the intake manifold. It's about 1in x 3in.that is where my VIN is located for the block. Hope you can find it.:hmmm:
  3. safado
    safado Member
    West Phoenix, AZ
    some have it some some don't, but its usually on the top of the block on the flat surface.. where the intake would sit..
  4. mean_maverick
    enjoy.......
  5. coutangman
    coutangman Member
    Charlotte, NC
    Thanks for the replies. The '67 has no marking in the flat place mentioned. I plan to pull the engine/trans out of the '72 gold GT tomorrow, so I will check it out then.
    Jim
  6. coutangman
    coutangman Member
    Charlotte, NC
    I pulled the engine/trans today on the gold Comet GT. The vin # was just where you said it would be and it is #'s matching to the car.
    The '67 doe not have a flat spot like this behind the manifold, only a long slot similiar to the short one on top of the '72 engine.
    Anyway, thanks again.
    Jim
