Engine wont stop
Discussion in 'Technical' started by x72COMETx, Feb 9, 2014.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Engine wont start
    Engine wont start its getting spark and sometimes it will run for like 2 seconds but wont stay running any suggestions
  2. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Sounds like fuel/carb issues.
  3. Dave B
    Won't stop, or won't start?
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    Wont start sorry
  5. 71gold
    was thinking the same thing...:yup:
  6. Bryant
    do you have gas in the tank?
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    Yes its getting fuel it will crank and turn over like its going to start but it just doesnt run
  8. Jamie Miles
    See if you're getting power to the ignition with the key in the ON position. I've seen ignition switches fail in way that the car would start for a second while cranking it over, but die as soon as you release the key.
  9. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I'd bet its a timing issue, recheck TDC. If it has gas and spark it should fire up.
  10. x72COMETx
    x72COMETx Member
    Vallejo CA
    Ive checked the timing its hotting its marks but im seeing it jump around sometimes to could the timming sprockets not have been put on right
  11. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    If its jumping around I'd say your distributor is bad. I had one doing that, but was running decent, and found out my distributor was bad. Either way if its jumping around you have timing issues that need to be resolved before you can really diganose anything.
  12. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Balancer can only be installed one way. Pointer could be installed incorectly but I doubt it. If your timing marks are jumping around then you have issues that need to be checked. If its not try moving the distributor around and see if you get any better results.
  13. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    It sounds like a worn timeing chain or gears to me, or may be a worn distributer shaft drive gear.
  14. x72COMETx
    x72COMETx Member
    Vallejo CA
    Ok i took the timing cover off today and noticed my timing tabs werent pointed towards each other so i fixed that and then took a look at my distributor and the points were burnt.
  15. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    What are points? :rolleyes:
