excaust manifold
Discussion in 'Technical' started by tommyboy, Feb 26, 2011.
  1. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    Hey guys i have a 77 maverick with a 250 and it has a cracked exhaust manifold i was wondering what would be the best way to get it off so i can have it fixed or might just replace!:hmmm: thanks!!!!
  2. injectedmav
    injectedmav Member
    Georgia
    you're probably going to have to replace it. never had any luck trying to fix them.
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    theres a good product called fire2000 by por-15.
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    [ame="http://www.amazon.com/FIRE-SEAL-2000-1400F-ALUMINUM/dp/B003MC759W"]Amazon.com: POR 15 FIRE SEAL 2000 HALF PINT 1400F ALUMINUM: Automotive[/ame]
  5. gmatthew76
    gmatthew76 Member
    Freeport, Fl
    1976 2 dr Maverick, 1977 2dr Maverick,1998 Ranger, 2004 Focus Wagon
    Header?
    Why not look at replacing it with a header. I just ordered a single outlet header for my 250 Maverick. I found some very good prices on the web at www.mustangsunlimited.com. Just put 250 headrers in the search box
  6. blugene
    I never had luck repairing a cracked manifold either. Taking them off can also create more work when studs break etc.. but that's pretty much expected.
    I could be wrong but I thought I read that the outlet is at a different angle for a Mustang header and would require a wild bend.. :hmmm:
  7. PaulS
    The best way to fix any cracked cast iron or steel part is oven brazing. It takes special equipment but in essence the whole part is placed in a high temp oven and the crack is closed using a brass, bronze or silver brazing compound depending on the levels of stress on the part. The repair is strong and has more flexibility than welding. Since the whole part is heated there is very little stress caused by the repair. It is not cheap but it will last longer than the original part.
  8. baddad457
    Swap in a V8........................................problem solved:thumbs2:
