Exhaust help
Discussion in 'Technical' started by Blue Brick, Feb 9, 2012.
  1. Blue Brick
    Blue Brick Member
    I have a 302 2V 100% stock and will remain that way internally, and I want to free up the pressure in exhaust, but without permanently modifying the car, so drilling holes or wields are not eligible. I need to keep the cats and all other emission equipment. Plus I need to keep it as cheap as possible. Any suggestions….. Horse power is not the issue with a 2.47 rear end but sound and little mpg might be nice.
    My thoughts……
    Dual exhaust with stock manifold, cats, and small cherrys, out in front of the rear tire.
    Or
    Singe 3 inch a with stock manifold, performance cat, and small cherry out the back with twin tail.
    Or
    Leave it be…..
  2. Bryant
    im not sure why you have to stay with a cat. if you are in California you can only have the same amount of cats that the car came with. so with that in mind i would replace the stock cat which origanly would have been a pellet type cat that is highly restrictive with a modern honeycomb style cat. then a 2.5" single exhaust following the factory routing out the rear of the car. a performance muffler of your choice for sound level will finish it off.
    if your in a state the doesnt limit you to the factory cat location you can do a dual exhaust system. you can put exhaust hangers for the drives side system on the seat belt bolts that stick out. its hard to fit a tail pipe in on the drives side so its easiest to just have the exhaust dump before going over the back axle.
  3. Craig Selvey
    I vote leave it be.
  4. Blue Brick
    Blue Brick Member
    Will this alone make a big difference? How much horse power and mileage can I expect with dual vs. single? In my state each pipe has to have a cat.
    Why?
  5. baddad457
    Run straight pipe without the muffler. The cats quieten it down more than the muffler does anyway.
  6. Blue Brick
    Blue Brick Member
    Single pipe?
  7. baddad457
    That's your call.
  8. Blue Brick
    Blue Brick Member
    I was asking what you thought...
    Does it need dual? Is it constricting?
  9. Blue Brick
    Blue Brick Member
    The reason I ask is that 302 HO GT’s, 351 HO Trucks, and 351 HO Crown Vic all have single yet have at least 157 HP.
  10. baddad457
    Run a dual 2.25 to 2.5 inch system or a single 3-3.5" pipe. I would try it without the muffler first, then if you don't like the sound, put a muffler on it.
  11. Craig Selvey
    Because you said you want to do it as cheap as possible. In that case...why do anything? With your motor described as: 302 2V 100% stock and will remain that way internally I don't see any advantages to be gained with any exhaust modification.
  12. Blue Brick
    Blue Brick Member
    Ok, thanks.
