exhaust question
Discussion in 'Technical' started by mavron 70, Jun 21, 2007.
  1. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    Hi all, does anyone know, if say 66 mustang tri y headers will fit a 70 maverick? Looking for a cheap header with plenty of clearance thanks, Ron:cheers:
  2. PaulS
    The original 289 Tri-Y headers don't fit in the Maverick. Some of the copies might.
  3. maverick75
  4. mavron 70
    mavron 70 Member
    R.I.
    thanks guys
    thanks for the advice!:drive: guess i know what tolook for,
    Now if I could shake a few dolars loose from that money tree.......
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Passenger side fits perfect.
    The driver's side actually does too, as long as you don't want to turn left.;)
    If you have a manual tranny, the linkage hits too.
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    thats a manual car in that pic?
    seams like "flow" would be restricted just a bit;)
  7. ratio411
    ratio411 Member
    Pensacola
    Yeah.
    The rod and spring in the upper right of the pic are running between the Z-bar and clutch arm at the bell.
  8. mavron 70
    mavron 70 Member
    R.I.
    nothing good is easy I guess, thanks.....manifolds will work for now
  9. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Do a search on "headers" and see what turns up ;) .
