Extended Wheel Studs..rear
Discussion in 'Parts Interchange' started by DonO, Apr 19, 2005.
  1. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    Hi guys, as a temp fix for a slight rub with my rear tires I thought
    about using wheel spacers and extended studs. Anyone know what
    stud I should get and if the knurl is .625 dia for a Ford? My local auto
    parts store isn't too helpful. Spacers are about 3/8 thick. Thanks, Don
  2. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Knock one of the studs out of your axle. Use a micron gauge to measure the knurl or take it with you to the auto parts store and let them size it up. Remember to add 3/8" on the length to allow for your spacer.
  3. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    Pick up some studs.
    Grabbed some studs last night. Got the old ones out and then
    realized I didn't have a std lug nut to use to pull them into the
    axle flange. Stopping after work to grab some std lug nuts and
    washers. Of course the weather is changing here from the low
    70's into the low 40's...Ohio is awesome!
  4. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    Studs Are In
    Well gang, the studs are in and worked great. If anyone needs the
    part number, I used the 98249 stud from Auto Zone. Only problem
    I had was my son cross threaded one of the lug nuts and I ended
    up breaking it off removing it. So out came the hammer and we thru
    another stud in and this time I watched him as he put the lugs back on.
  5. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Good idea...posting the part number. I'm sure someone else will be able to use the info sometime.
    Later,
  6. stmanser
    Davenport, Iowa
    you know....the last time i went to the drag strip they wanted me to have studs that stuck out past the nuts at least 1/2". they said it was a NHRA rule....but i have never heard it before.... so before i go back i need to change the studs....i will do it on the used rear end i got...
    the question i have is hoow do you get the used studs out..i tried hitting them with a hammer but the arent budging...ideas?? pullers? cant get access to the back side without taking the brake stuff off...
  7. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    I easily beat them out with a hammer. Could be another way,
    but that worked for me.
  8. stmanser
    Davenport, Iowa
    cool thanks
  9. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Hey Don, How long are 98249 studs. I got some from ARP but they are 3 inches long. I can't get them in without slidding the axle out a little.
  10. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    Streetrod
    That's a good question. I didn't actually measure the length
    before putting them in. The stock studs are very short and
    these were at least 3x longer. They barely fit in behind the
    axle flange when I installed them. I rotated the flange around
    to the 3 o'clock position and slipped it in using the open space
    there. Hope that helps.
  11. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks...I need to look in to that. I got some made by ARP but they are 3.5 inches long & I haven't put them in because I will have to slide the axle out a little to get clearance.
