fabricated a brake cable bracket
Discussion in 'General Maverick/Comet' started by Dan Starnes, Feb 5, 2005.
  1. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Still working on getting ebrake cable for my Stallion rear disc brake setup. Different cables require different brackets. Fabbed this one up late this afternoon. As you can see it is quite small, that is a dime in the foreground. Showing it in the ruff, still will grind down the welds. It is made from 16 gauge sheet metal. Getting into the fabbing stuff up mode again. While this is a very small piece, it was quite challenging because of that. You are looking at 4 different pieces of sheet metal. Think I will do a 90 degree bend on the next one, that way only 3 different pieces. Less welding.
    Dan
    :banghead:
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    WOW! Good job Dan! Neat way to spend a Sat, making what you don't have and probably can't find any way. (y)
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Hmmmm.... I have an old watch that needs repairing. :confused:
    :D wtg
  4. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    Cool bracket Dan. How is your cable operated emergency brake going to work with your rear discs? On an old Supra I used to have, it had sort of a mini drum inside the rotor that was connected to a mechanical parking brake. I'm not sure how the newer cars manage to use a mechanical parking brake without this type of setup.
  5. 71gold
    i hope it works a lot better than it looks :bouncy: j/k....frank...
  6. Mavaholic
    Fabbing up stuff is a lot of fun. Looks great.
  7. Dan Starnes
    West Central IL
    Yes, there is a mini drum setup for the parking brake. Explorer setup. Basically just setting it up underneath like an Explorer. Now need to weld that bracket to the car and see how it works. The Stallion has a ratchet type foot operated park brake.
    Dan
  8. riporter
    riporter Member
    Charleston S.C.
    Some nice work Dan to be so small, see if that had been me I'd a welded it to the vise.:banghead:
  9. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Ditto!! And let me tell you, it woulda been hell to get the bracket AND the vise mounted under the car......... J/K Looks good to me Dan. Wish I had the time to do things like that. Keep it up!! Preston
