Fan and Fan shroud Question??? Help!
Discussion in 'Technical' started by mark_b, Oct 27, 2002.
  1. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    Need advise. Just put the v-8 in the car thta had a 200ci .
    The fan shroud is smaller than a v-8 shroud.
    Question is:
    Can I take the fan off the 200 ci. motor and put it on the 302 so I can use the shroud even though it is a bit smaller?
  2. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    Hmmm
    I dont really know first hand but if it were me i would try it ...
    After i installed the smaller fan and shroud i would make sure i had a temp guage set up and run the car to check what temp it runs ... The worse that can happen is that it wont work ,In that case your only out a few hours of your time ... Just be sure your guage is accurate and you dont run it too hot ... can you add a slimline auxillary pusher fan in front ?
  3. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    my car doesn't have a shroud...got a BIG!!! fan though...
  4. Craig Selvey
    I don't think that will work.
    AutoKrafters now sells V-8 fan shrouds. I would suggest buying one of those.
  5. mark_b
    mark_b Member
    western PA.
    Craig,
    Thanks for the reply...and thanks to you, I have my 72 302 in and running(spacer plate)!
    But I must ask why you thing it would not work?
    Lack of air movement thus poor performance. Just plain wont fit!?
    Shroud wont fit on radiator?
    Mark ( NO more cash) B.:confused:
  6. Craig Selvey
    The 6 cyl shroud is not "centered" like the v-8 shroud. It is offset to one side. Won't work with the v-8.
