Fan clutch reverse rotation?
Discussion in 'Technical' started by engineerHK, Mar 17, 2012.
  1. engineerHK
    engineerHK New Member
    Guadalajara
    Maverick 76
    hi all
    I already swapped a 5.0 HO in my mav, i did not put SERPENTINE BELT otherwise i went for old style or V-BELT. I got a fan clutch so i requested for a maverick from the seventy's but the box said: REVERSE ROTATION. do i have the wrong fan? Should i change it for a Standard Rotation?
    any help is welcome
    thanks in advance
  2. bmcdaniel
    bmcdaniel Senile Member
    Sounds backwards to me and you also need a standard rotation water pump.
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
  4. engineerHK
    Guadalajara
    Maverick 76
    Great thanks! just one thing, what about thermal or non thermal? could you explain me how it works?
    Thanks in advance
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Thermal clutch releasing when cold and grabs when hot. the non thermal just grab a release base on rpm and drag. If you are going to keep a fan clutch instead of going to a flex fan then you might as wel go with the thermal clutch cause its the most beneficial.
