Fan Shroud
Discussion in 'Technical' started by Slider28, Feb 22, 2010.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    My 72 Grabber came with a shoud, but it was all busted up and i removed it. I have been driving it without it, but i wanna get another one.. My question is.. My car DID NOT come with factory air, I bought a Aftermarket AC unit that came out of a 72 Grabber, that im going to in stall in my Grabber... Do i need to get a shroud that has factory AC or WITHOUT factory AC???
    Thanks!
    Chaz..
  2. Craig Selvey
    I would say WITH factory AC in order to make sure you clear the compressor.
  3. mojo
    I wud think the fac. shrouds might be the same, Im not sure. I wud also think that any shroud u can find in gud condx. - grab it. Some of the long time Mav\Comet guru's have a definitive answer. My car has fac air; I believe any shroud is more efficient than just open fan. Also, there's the safety issue of a open fan. IMO try to find one.
  4. Slider28
    Slider28 Member
    San Antonio, Texas
    Ok! Now where can i get a good used one that isnt gunna make me sell blood and sell a kidney??
    CHaz.
  5. mojo
    I wud suggest the parts wanted\for sale sections of this forum, ebay or the boneward - that's what I wud do. Gud Luck
  6. yellow75
    Tillamook Oregon
  7. apotter80
    apotter80 Member
    charlotte, MI
    1971 maverick grabber(CLONE)
    i don't run a shroud at all. as long as you have a good fan to pull enough air......but there is that safety issue as previously stated. :huh: all i can say is my car runs at 195 degrees when its 90 outside. i run a plastic flex-a-lite fan blade.
  8. Dave B
  9. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    I don't think my car ever had a shroud and mine run's great. I use a Summit 6-blade fan now, soon-to-be an electric fan.
  10. Slider28
    Slider28 Member
    San Antonio, Texas
    Well i found out my "TEMP" light worked. I had to sit in line in traffic for 10 mins in 96 degree weather and NO SHROUD and the TEMP light started to flicker. Luckly as it came on, i got to drive and it went away.
