FAQ: What size rims fit the maverick?
Discussion in 'General Maverick/Comet' started by DarthMaverick, Apr 28, 2005.
  1. DarthMaverick
    DarthMaverick The Yang of Mavericks
    Bakersfield
    1976 2 door Maverick
    Will a 10 inch(25.6cm) rim fit? No. In my experience there is aproximately 11 inches of space underneath the wheel well. The wheel flange* is about adds about an inch. A 15x8 wheel with a 3.75 backspace** will fit with 225/50/15 all the way around. Always measure first then fit the tire. 245mm tire can be run all the way around but are taller than factory stock. You may also need to run revised aftermarket control arms in the front because of camber problems inherent in the design. They camber the tire outward and cause rubbing with 245's in the front.
    A competent shop can bulge the fenders allowing bigger tires, but the same backspacing and tire height should be kept so the tires do not rub on full turns. Note that the size 245mm indicates the size of the entire tire, not just the tread. This site will help you with your tire fitment calculations:
    http://www.miata.net/garage/tirecalc.html
    http://www.1010tires.com/TireSizeCalculator.asp
    * Wheel flange - The part of the wheel that is the 90 degree angle that the bead sits on. The wall of the tire presses against the wheel lip seen from the outside.
    ** Backspace - The distance from the inside mounting surface of the wheel to the lip. ALWAYS measure to the lip.
    ***Camber - The amount of degrees the wheel leans into the wheel well during cornering or bumps. Most car tires have a little camber while at rest.
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    There are variables. With 225/60-15s on the front, a 3-3/4" backspace, and 1 full coil removed, I had rubbing on the outside fender lip on turns. Since I don't want to go with a narrower tire, I plan to go with a 4-1/4" backspaced wheel...
  3. buckcreek
    buckcreek Member
    somerset, ky
    73 MAVERICK STANDARD 2dr 302 auto.
    Are there any mustang rims that will fit on my 73 mav.
  4. Mavaholic
    Are you talking about old mustang or newer mustangs. 4 lug or 5 lug?
  5. buckcreek
    buckcreek Member
    somerset, ky
    I was looking at the 5 lug set up that is what is on the car now.
  6. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Bullit Wheels??
    Just wondering what the spacers are for?Is it to change the bolt pattern or to bring the wheels outward more.Thanks Derek.
  7. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    They are to set the wheels farther out, the wheels are the same bolt pattern .
  8. stmanser
    Davenport, Iowa
    from what i have heard and the setup i am going with is as follows
    255 60 15 tires and a 15x8 rim with 3.75 backspacing.. it all fits.. this is all i am worried about.. later i will get some slicks in this same size.. and then have some fun
  9. Fonz89
    Fonz89 New Member
    Bakersfield
    Maverick
    Hi, i was wondering if 17x8 mustang cobra rims would fit in the front of my 76 mav. They are 5 lug. heres the wheel size 245/45ZR17. Any info would help.
  10. maverick75
    With mods it can, They have the same bolt pattern but you will need to use spacers because they have between 5-6" of backspacing, i plan to use the 17x9 2000 Cobra r's with a 1.25" spacers.
