FE headers
Discussion in 'Technical' started by HWeiss, Nov 28, 2002.
  1. HWeiss
    HWeiss Member
    Kalona Ia.
    Why does Hooker list a FE engine header to fit a maverick? Do those engines actually fit? Also does any one know,are the spark plugs and header bolts as hard to get at on a 351W as a 351C in a Mav? I have a 351C in mine and am planning on a 351W,to get away from the tight shock towers.Thanks. :D
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have had a few FE's in my time. I love um,,,, but I WOULD
    not want one in a Mav/Comet. Too much fabrication to make
    it all work. Probably best to think in terms of a stroker if you
    are after horsepower. Just my opinion.
    Dan
  3. don graham
    i can tell you that there is not a lot of room in a 351w in a maverick. changing plugs is not a job i look forward too. and it's coming pretty soon.:(
  4. HWeiss
    HWeiss Member
    Kalona Ia.
    Don
    Don,Do you know how changing plugs compare between the cleve and windsor in a mav?
  5. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    ID SAY CHANGING PLUGS IN A WINDSOR WOULD BE EASYER THAN CLEAVLAND.ARNT THE HEADS ON A CLEAVLAND WIDER.JUST A THOUGHT.I LIKE THE STROKER IDEA 427 WINDSOR THAT BE SWEET.
  6. HWeiss
    HWeiss Member
    Kalona Ia.
    plugs
    killercomet,I think the strocker windsor is a great idea,I just pulled out a 351c and vowed never to fight headers or spark plugs like that again:mad: The c heads are wider but the windsor deck height is taller,thus making the engine wider.Well maybe I should stick with a strocker 302.
