Fender Badge Removal
Discussion in 'Technical' started by Ryan Whiteside, Nov 11, 2014.
  1. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    Tried searching and didn't find anything really about the removal process. Need to take mine off to refinish them and not sure how they are attached. Any information would be appreciated.
  2. Acornridgeman
    Wisconsin
    They have 3 pins that are pressed into a small fastener called a barrel nut. Very carefully pry the script emblem out from the fender and it will come out. Make sure the pins pull back away from the barrel nut straight or they can break.
    This is what the barrel nut looks like
  3. Craig Selvey
    I would pry a little on each side and pry it out EVENLY
  4. Ryan Whiteside
    I've got a couple small nylon flat forked pry bars. Believe that will be my best bet for getting under and pulling them out straight and even. Thanks for the help fellas.
  5. Acornridgeman
    Wisconsin
    I should add, the 3 pins are located at the top left side of the M, the center of the K, and at the top of the steer horns.
    This does not apply to the trunk emblem. That one is held on with automotive adhesive tape.
  6. Ryan Whiteside
    That's definitely good to know.
  7. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
  8. Ryan Whiteside
    Luckily got both them off without anything breaking.
  9. Acornridgeman
    Wisconsin
    :bananaman:
