Fighting with my carb/timing setup....
Discussion in 'Technical' started by 72MAVGRABHER, Mar 25, 2009.
  1. 72MAVGRABHER
    Roanoke, Va.
    well, edelbrock says to set it at 16 degrees initial setting on the 302 performer rpm cam and heads to be "safe: Now, i know theres plenty more room, but haven't messed with it until i can get her to the dyno to see where my peak is...
    its set at that 16 degrees, but with the 750 holley vacuum sec, shes running waaaay rich at idle. (ex - black smoke, eyes burning, etc.) also sneezing through the carb when shes cold. When she warms up however, it doesnt do it as bad, and seems to smooth out. The idle air/fuel mixtures are set right, main jet from 70 to 69 for our elevation. Now this is the carb holley and CHP told me to get since there will be nitrous on it after break in for track use occasionally.
    any recommendations?
    It's actually a 347 with the rpm airgap intake, rpm heads with 2.02 intake with a little work done, rpm cam to complete the edelbrock top end package (changed over from another cam)... 10.0:1 compression and a holley 4160 750 vacuum sec 4bbl. also the infamous doug thorley headers....
  2. Bryant
    set the timeing to 32 degrees with the vac. advance line off and pluged with the rpm at 3000 rpm.
    that will give you a good starting point. that 16 degrees doesnt make much sence.
  3. Bryant
    i dont feel that you can acurately set jeting just by description and altitude. there are so many variables. on the 750 dp holeys they have 4 idle mixture screws. i ran one on a 351 and each one was bearly cracked off its seat to get it to idle correctly and not bog. i prefer to use the 700 cfm dp holeys on motors around this size just because it only has 2 idle speed screws.
  4. krelboyne
    krelboyne Remember
    Salem, Oregon
    I'll add my dos centavos. :bouncy:
    Get a vacuum gauge and adjust timing and carburetor for maximum vacuum.
    Hook the vac. gauge up directly to the manifold.
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    How much vacuum does it have at idle? Might be pulling in the power valve. I agree no book or directions will tell you what jet to run. I have a very mild 460 in my F100 and with the 3310-750 cfm carb I used to run on it I had 65 jets in it. It was still rich. I run a 600 now.
    clint
  6. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    idle
    Sounds like your primaries may be too far open, you may be off the idle circuit. You should have the secondaries adjusted about .015 open . As noted above get the timing thing right first , then start messing with the carb. I also would wonder about the power valve. Holley puts out a pretty good tuning book available at most speed shops. Let us know what you do to solve the problem....
  7. 72MAVGRABHER
    Roanoke, Va.
    currently has 11 hg of vacuum at idle and im ordering the 5.5 or 55 power valve to swap out this week... i will adjust the timing accordingly and check my secondaries soon as my car gets back from paint... thanks for the tips so far...
  8. Blown74
    Blown74 Member
    Va
    sounds good
    Yea - base timing first..its a constant, once set won't change. Then go to work on the carb issue. 5.5 PV sounds about right based on your vacuum readings. Open the secondaries until the transition slots are just barely exposed, then start working on the airbleeds using the vac guage, fronts first then secondary. Adjust for highest possible vac reading you can achieve. Where are you in Va?
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    THings is I bet those bleeds are not adjustable without drilling.
    I bet the above author is right and his primaries are off the seats. Bet he needs to open the secondaries
    11" ought not open a stock 6.5" power valve.
    clint
  10. 72MAVGRABHER
    Roanoke, Va.
    20 mins north of Roanoke
  11. Bryant
    thats how i adjust my idle mixture. once you get the highest vac possible, your there on your idle mixture. the rpm may go up or down as you adjust it, so turn it back to your desired rpm as you go. do each idle mixture screw a little bit at a time trying to keep them within 1/2 to a 1/4 turn of each other.
  12. 72MAVGRABHER
    Roanoke, Va.
    Hah, guess ill update this post from way back when lol.
    The doug herbert GM Conversion distributor i was running was to blame. It never curved, and was junk from factory according to Terry Walters Racing Engines. they went to dial it in on their machine and noticed a binding inside the shaft. So, now im back to running a stock distributor with pertronix and had it dialed in and curved so that its all in by 3000. Trip to dyno this year should show a heckuva increase. Funny, i always seem to acquire the broken NEW parts.
  13. baddad457
    He's got a 3310 vac sec 750. :tiphat: 2 idle screws.
  14. Blown74
    Blown74 Member
    Va
    soo ???????
    Did that fix everything? Did you do anything to the carb? Fill us in please on the results.
  15. bmcdaniel
    bmcdaniel Senile Member
