Figured out the brake issue... now what?
Discussion in 'Technical' started by TarHeelDevil, Aug 26, 2012.
  1. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    Hey folks, I found the leak in my power steering system, and I must say I'm kind of embarrassed it took this long. In my defense, I haven't gotten under the car with it running until now, but still, its a pretty obvious problem. There's a pinhole leak in one of the lines but I don't know which part number I need from autozone. Also, how do I actually dis/re-connect the line. I'm really sorry if I seem like an ignoramus- it's because I am. Trying to learn though!
    This pic is from the front of the car, just inside the drivers side tire. the arrow indicates the obvious hole in the line.
    So Which part number would I need, and is it just a simple screw on/screw off thing?
  2. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    If you can't find the part, some NAPA auto parts can make you a new with your old hose.
    Rick
  3. Dave B
    Extremely common part, Control Valve to cylinder Hose, 3A717-42B is the National Parts Depot number, $49.95, EA. Wooo, I didn't think they were that much...
  4. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    Thanks y'all! is it just screw on/off?
  5. Dave B
    Yes, it's best to use some "Line Wrenches" that way you won't round anything off. You could look around the net, I'm sure you could find those hoses cheaper, look under 68 Mustang.
  6. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    thanks Dave:)
  7. Dave B
    I just looked on Ebay...Boy...they are expensive there also, I can't believe I spent 90 bucks on 2 hoses...If you look, the 65-66 hoses are different.
  8. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
  9. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Check RockAuto. They have a few left, $5-$14.
  10. Dave B
  11. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    Thanks to all for the input!
  12. simple man
    simple man Member
    Bunnell,Florida
    In your photo I see what looks like a radiator type hose clamp that is in a position to chew a hole in that hose! I don't know what it is there for, but please check it out before replacing your hose. Also I got my hoses at NAPA for around $20! I'll admit that was a couple of years ago, though. :)
  13. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    wow- I'd be willing to bet that that's what caused that hole!
  14. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    those leaks are why i am converting to manual steering just waiting for the center link. put to many fords sideways during snow and rain ( or when Spokane washes the streets during a 30 degree mourning) because of ford power steering :cry: mine looks like its leaking from the ball socket of the control arm and was almost less to convert.
  15. TarHeelDevil
    TarHeelDevil Member
    Chapel Hill NC
    None
    So I picked up the part, now how do I bleed the lines?
