Finally got the EFI Project up and running.
Discussion in 'Maverick/Comet Projects' started by Clintd, Oct 7, 2010.
  1. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    I haven't been on the forums in a wile because I have more projects then time.
    I finally got around to wireing up the maverick and getting it all running. All that's left is exhaust and some neataning up.
    This is a 95 mustang GT engine with 49,000 miles, gt40 intake, 65mm throttlebody, 24# injectors, gt40 heads milled down 20 thousands, AOD automatic with a B&M shiftkit, 3000 stall converter, 3.80 track-loc rear and headman shortie headers.
    I'm using a A9P ECM to run it all and a C&L maf for the injectors.
  2. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Man that motor sounds good.
    Nice job.
    Rick
  3. Clintd
    Clintd Member
    Parlin NJ
    I'm going to put turbo mufflers on it to make it nice and quite and the exhaust is going to come out over the spring behind the rear tire so that it looks like it only has 1 pipe. I'm keeping it baby blue with the hub caps and white walls for a wile. It will be fun suprising all the ricers around here.
