finally!!!!!!!!!!!!
Discussion in 'General Maverick/Comet' started by monster 302, Nov 29, 2007.
  1. monster 302
    monster 302 Member
    Meridianville,Alabama
    1976 ford maverick
    well its been two weeks now that my car has been off the road due to a piece of metal rod destroyin two pistons.But theay both came in this mornig and i can get it put back to gether and stod driving my dads truck.And i am puttin the hastings piston rings on all the pistons for better compression,and while its been down i whent ahead had it boared to 40 over.:bananaman
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Should be a beast soon enough.
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I'm a little confused here? You say both new pistons came in today,then you go on to say you bored it 40 over.Did you just bore two cylinders 40 or all of them? And if you bored all of them areyou just going to let the other 6 just slap around in the holes? :hmmm:
  4. don graham
    "while it was down you bored it .040 over". what was it before? if you bored it .040 over and it was not that way before, then you need all new pistons and rings to match the oversized cylinders now.:huh:
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    What they said. If you only bored two, those pistons are going to be slightly heavier, and throw the balance off. :hmmm:
  6. monster 302
    monster 302 Member
    1976 ford maverick
    i had the entire engine tore dowm and had all nwe pistons last two showed up to day had all cylinders bored 40 over while it was down.
  7. don graham
    that clears it up. sounded like you only got 2 pistons. that's what i have in my bracket car. 308. good luck with it.:)
  8. scooper77515
    That is what mine is growing up to be...308!!! Let us know how it runs when you get it done. Mine is almost there. Just need a couple last-minute parts...
