Finding the right spacers
Discussion in 'Wheels and Tires' started by Racer_X, Mar 7, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    so i have been trying to narrow down the correct spacers for my cobras, my wheels are 17x9 with 6.02'' bs and 1.02'' offset, the only person i know of that had/has similar wheel specs is mean_maverick mine are a tad bigger than his. he used 1'' on the front and 1.25 on the back. im thinkn i should use 1.25'' up front and 1.5'' to 2'' on the rear. what do you guys think?
  2. mercgt73
    mercgt73 Member
    I think you should use washers (on 3 of the 5 studs) to space out the wheels. Then once you find the best position, measure the thickness of the washers (or the distance from the back of the wheel to the hub).
  3. rthomas771
    I'm not a big fan of any wheel spacers over 1/4". They put too much load on the studs and could shear the studs. If it was me...I would buy rims that fit without using spacers.
  4. Dave B
    Spacers on the front, scare me...even with ARP wheel studs.
  5. injectedmav
    injectedmav Member
    Georgia
    I have always recommended using a high quality bolt on spacer with it's own studs for anything over 1/4". The washer method will give you the depth, that's the way I would do it too. You may run out of stud length with wheels with that much B/S but I would give it a try.
  6. Racer_X
    North Carolina
    was thinkin about that last night, wouldnt be hard to sell them
