Firewall and wiper stuff needed
Discussion in 'Technical' started by GrabberGT, Mar 13, 2010.
  1. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Hey gang. Im looking for some parts to put together my firewall and dash. I need to know where to get the following:
    -plastic/rubber sleeves that mount over the windshield wiper shafts
    -wiper arm to cowl seal/gasket
    -gasket/seal for the steering column plate on the firewall
    Anyone have ideas? Will I be making this stuff myself? If so, what kind of material will I need?
    Thanks
  2. tody
    tody Member
    cologne, germany
    1. don't know what part you mean...
    2. got mine from mustangsunlimited, autokrafters will have them, too
    3. autokrafters sells this seal
  3. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    know onw makes covers for the wiperarm shafts...and autokrafters for the rest as stated above
  4. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    are they needed?
  5. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    No one makes them.Have to get them from someone or a parts car.And no,not needed.If i remember right only the driver side had it,(from the factory)and the passanger side was empty.
  6. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    What does ONW stands for?
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Look at the quote two posts before your, in there it says "know one". The post was either edited after it was quoted or corrected by GrabberGT. Either way, I think he was saying "no one".
  8. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    :slap: Right on, thanks.
    RMiller likes this.
  9. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I bought a kit of various size rubber grommets from Harbor Freight. There were some that fit snug over the outer wiper shaft and fit the hole in the cowl. What I did have to do was freeze the grommets to make them hard and then sand down the top side so that the wiper arms would not drag on them. I put them on both driver and passenger side. For the underside cowl gaskets I used reproduction early Mustang leather ones. The foam steering column to firewall gasket is available, it may be a Dennis Carpenter piece, I cannot remember.
    RMiller and Comet79 like this.
  10. Comet79
    Comet79 71 Cometa
    Northern California
    71 Comet
    Thank you Jason, your knowledge is greatly appreciated.
